Hi there. I just went through a week of trying to put our free Letâs Encrypt certificate on our Bluehost account and I want to share my experience.
I learned that our particular Bluehost account server is running CentOS 6. Since we are paying for a dedicated IP we have SSH access, but not root (admin) privileges. Bluehost uses cPanel and cPanel are currently in experimental phase of providing Letâs Encrypt SSL certificates. I found this link, but couldnât implement the steps, because it requires root (admin) privileges: https://forums.cpanel.net/threads/how-to-installing-ssl-from-lets-encrypt.513621/
Next, I found that https://letsencrypt.org/docs/client-options/ mentioned https://gethttpsforfree.com as a non-SSH way to generate a Letâs Encrypt SSL certificate. I went through the steps and successfully generated a Letâs Encrypt SSL certificate and later learned that it mimics the same steps as the command-line certbot
tool. However, I made a grave mistake, which cost me several days to fix: I generated a 4096 byte private key: Bluehost seems to work only with 2048 byte private keys! All the websites I visited to learn about SSL certificates pointed out that they recommend a 2048 byte key, but I thought I might as well go for a key that is twice as much secure - and totally useless! When I called Bluehost tech support and told them I was ready to install my shiny Letâs Encrypt SSL certificate generated with a 4096 byte private key, they told me: âYour private key doesnât match your certificate.â What? How could that possibly happen? I believe I actually confused the account key with the private key. I later found on https://www.sslshopper.com/certificate-key-matcher.html that the MD5 hash from the private key, the Certificate Signing Request and the certificate itself has to match. Once you successfully generate an SSL certificate, you can run the following commands to check whether the componentsâ MD5 hashes match. For example, when I run these commands this is what I get:
$ openssl x509 -noout -modulus -in cert.pem | openssl md5
(stdin)= 16f96a4606acd0ac4ff094497a61ea62
$ openssl x509 -noout -modulus -in fullchain.pem | openssl md5
$ openssl rsa -noout -modulus -in privkey.pem | openssl md5
$ openssl req -noout -modulus -in bluehost_csr.asc | openssl md5
However, the 4096 byte account key and subsequent certificate I generated produced MD5 hashes which didnât match. The only option I had was to revoke that certificate generated with the 4096 byte private key, because I didnât have the private key, but only the account key. I used a computer with Ubuntu 16.04 LTS (Xenial) and installed certbot
on it using the steps outlined on https://certbot.eff.org/#ubuntuxenial-other and I revoked the certificate using the following command:
$ sudo letsencrypt revoke -d mydomain.com -d www.mydomain.com --cert-path signed.cert --key-path account.key
Next, I was checking the status of my old certificate using https://certificate.revocationcheck.com - it took one day for my old certificate to become revoked. I had shot myself in the foot with the 4096 byte private key.
Great. So, how to do it right? Here are the steps that worked for me:
Use a Linux machine where you have root (admin) privileges and install certbot
. In my case, I had an Ubuntu 16.04 LTS (Xenial) machine and ran the following commands:
$ sudo apt-get install letsencrypt
Generate a Letâs Encrypt SSL certificate with the default 2048 byte private key. Since we are generating the certificate on one machine and will be using it on another, we cannot use the automatic web server (for example Apache) configuration that certbot
offers; instead we will have to use the manual
option, since we will manually configure our web server. Actually, the Bluehost tech support will configure the web server for us. Also, itâs always a good idea to test whether you will successfully generate the certificate by doing a dry-run
, like so:
$ sudo letsencrypt --dry-run --manual certonly
Next, certbot
will ask you: âPlease enter in your domain name(s) (comma and/or space separated)â. Enter something similar to this: mydomain.com,www.mydomain.com
and select OK using the down arrow button and press Enter.
Next, certbot
will ask you: âNOTE: The IP of this machine will be publicly logged as having requested this certificate. If youâre running letsencrypt in manual mode on a machine that is not your server, please ensure youâre okay with that. Are you OK with your IP being logged?â Select Yes and press Enter.
Next, certbot
will say something similar to this: "Make sure your web server displays the following content at http://mydomain.com/.well-known/acme-challenge/mQrV3E4d5vIUrrmhs41ppa8drh66F409ZvE6QtAadJk"
mQrV3E4d5vIUrrmhs41ppa8drh66F409ZvE6QtAadJk.FblC_wtJqZv9yb8fLvTD4p8z1ilpeBUZ0E-ligwgsR8
Now you have to switch from your Linux machine to your Bluehost file system. Donât touch anything on your Linux machine; you must first generate the random web page requested by certbot
before pressing Enter on the Linux machine. Use SFTP or SSH to access your Bluehost account file system and go to the directory where the particular web site is hosted. In my case it was something like this: /home3/username/public_html/mydomain
Here you have to create the directory .well-known
and please make sure it begins with a period, because thatâs very important. Go inside .well-known
and here create the directory acme-challenge
. Go inside acme-challenge
and create a file with the filename as per certbot
, in my case the filename was mQrV3E4d5vIUrrmhs41ppa8drh66F409ZvE6QtAadJk
and next open the file and enter the one line as per certbot
, which in my case was mQrV3E4d5vIUrrmhs41ppa8drh66F409ZvE6QtAadJk.FblC_wtJqZv9yb8fLvTD4p8z1ilpeBUZ0E-ligwgsR8
Now open up your browser and make sure you can go to the web page as per certbot
, which in my case was http://mydomain.com/.well-known/acme-challenge/mQrV3E4d5vIUrrmhs41ppa8drh66F409ZvE6QtAadJk
If that worked, switch to your Linux machine where certbot
is waiting for you to create the web page to prove ownership of the domain and hosting, before it generates a certificate for you. You are now ready to press Enter to continue. Note that certbot
will ask you to generate a random web page for each domain you enter; since I entered mydomain.com
and www.mydomain.com
it asked me to generate two random web pages.
If certbot
could access your newly created web page(s), it will say that the dry-run was successful and you can now successfully generate your Letâs Encrypt SSL certificate by repeating steps 2-5 without using the --dry-run
switch on the command line, like so:
$ sudo letsencrypt --manual certonly
Your new certificate will reside at the /etc/letsencrypt/live/mydomain.com
directory on your Linux machine. You can also check whether the componentsâ MD5 hashes match by using the commands at the beginning of my post.
Otherwise, if certbot
couldnât access your newly created web page, it will report an error, and you have to repeat the process again from step 2.
Copy the files in /etc/letsencrypt/live/mydomain.com
from your Linux machine to your Bluehost account via SFTP or SSH - no root (admin) privileges needed, just remember the path where you copied these files, for example /home3/username/letsencrypt/live/mydomain.com
. You should find the following files in /etc/letsencrypt/live/mydomain.com
on your Linux machine: the generated private key privkey.pem
, the certificate cert.pem
and the CA bundle fullchain.pem
Also, upload the private key privkey.pem
to your Bluehost accountâs SSL/TLS Manager, and fill out the Certificate Signing Request using the uploaded Letâs Encrypt private key. First, the private key privkey.pem
should be uploaded on the âPrivate Keys (KEY)â section of your Bluehost accountâs SSL/TLS Manager web page; give it a meaningful name, such as âmydomain.com Letâs Encrypt private key generated on my Linux machineâ. Second, go to the âCertificate Signing Requests (CSR)â section of your Bluehost accountâs SSL/TLS Manager web page and generate a new Certificate Signing Request using your Letâs Encrypt private key you just uploaded, called âmydomain.com Letâs Encrypt private key generated on my Linux machineâ. You only have to fill-in the required fields on the Certificate Signing Request, but it is strongly recommended to enter an important email address. Press Generate and go back to the main SSL/TLS Manager web page. Third, the certificate cert.pem
should be uploaded on the âCertificates (CRT)â section of your Bluehost accountâs SSL/TLS Manager web page.
Call Bluehost tech support and tell them you have generated a 3rd party SSL certificate and uploaded it to both your accountâs file system at, letâs say, /home3/username/letsencrypt/live/mydomain.com
and uploaded it to your accountâs SSL/TLS Manager web page. They should be able to help you out.
Hereâs a much easier way:
Go to https://zerossl.com click on Online Tools
and click Start
on the âFREE SSL Certificate Wizardâ section. Now there are three major steps:
Details: Enter your email in the Email field, enter the domain(s) in the Domains field (for example:
), check the âAccept ZeroSSL TOSâ checkbox and the âAccept Letâs Encrypt SA (pdf)â checkbox, leave the radio button on the default option âHTTP verificationâ and click Next
. âCopy the generated CSR locally, for example, call it csr.txt
and click Next
. Copy the account key locally, for example, call is accountkey.txt
and click Next
Verification: Create the directory path
on your Bluehost account as explained in step 5 in the above example, and create the file with filename as per the File
field, and contents as per the Text
field. You can click on the link in the File
field to verify that you have successfully generated the random web page. Once you have verified that, click Next
Certificate: Write down your account ID generated by zerossl.com as they provide a service to restore a lost account key. Download or copy your domain certificate, in this case a bundle of several certificates, by clicking the down arrow icon above the text in the top box; its filename is
domain-crt.txt
equivalent to the fullchain.pem
generated by certbot
. Download or copy your domain key, by clicking the down arrow icon above the text in the bottom box; its filename is domain-key.txt
equivalent to the privkey.pem
. Note down the instructions on the Certificate page, they are very useful.
I hope this helps.
Best regards,
Denis
P.S.: Today I learned that SiteGround have a 1-CLICK procedure to get a Letâs Encrypt SSL certificate, because their cPanel has that option built-in!
