Setting up SSL on a Bitnami stack with AWS
Okay, I have two domains (one and older one and the other with our new name).
I have a sub domain. I have two AWS instances one being a Bitnami stack.
I have all my domains registered and DNS working.
I have SSL working on both servers but not totally right.
So I need www.domain1.com, domain1.com, www.domain2.com, and domain2.com pointing to one server with a working SSL
I also need store.domain1.com, www.store.domain1.com, store.domain2.com and www.store.domain2.com working on one SSL.
Thoughts?
Hi @juhler64
please start with the basics.
Then select a client.
If this is done and if you have problems to create a new certificate, please answer the following questions. That's the standard template of Help
Please take a look at https://docs.bitnami.com/aws/how-to/generate-install-lets-encrypt-ssl/
Thank you
My domain is: industresource.com is main. legacymachinery.com should point to the first.
sudo lego --tls --email="juhler@industresource.com" --domains=“industresource.com” --path="/etc/lego" run
sudo lego --tls --email="juhler@industresource.com" --domains=“www.industresource.com” --path="/etc/lego" run
Both of these work but I ended up with two certs. Not sure how to use two certs.
My web server is (include version): Apache2 2.4.34
The operating system my web server runs on is (include version): 16.04.5 LTS
My hosting provider, if applicable, is: AWS Lightsail
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): None
Lego Clients allow you to use mutiple domains in one command.
You should use sudo lego --tls --email="juhler@industresource.com --domains=“industresource.com --domains=“www.industresource.com” --path="/etc/lego" run
Thank you
Yeah I sort of figured that is where I messed up. It failed on that when I tried it at first.
What about the old domain name?
You should
  • create a certificate with both domain names
  • and a redirect (http status 301) old domain -> new domain
So you don't have duplicated content (the same content under different addresses) and the redirect is secure.
But the correct redirect is:
http + old domain -> https + old domain -> https -> new domain
[INFO] [industresouce.com] acme: Trying to solve TLS-ALPN-01
2019/05/06 22:06:51 [INFO] [www.industrecource.com] acme: Trying to solve TLS-ALPN-01
2019/05/06 22:06:58 [INFO] Unable to deactivated authorizations: https://acme-v02.api.letsencrypt.org/acme/authz/hLUMWm64xgaus9aUj8i7d_6rx5EMj9Fmie9yehlZ_TU
2019/05/06 22:06:58 [INFO] Unable to deactivated authorizations: https://acme-v02.api.letsencrypt.org/acme/authz/zTrVGIxwy_jhnZZj5gKRtI4PzZHd796YwlzqnSS71r8
2019/05/06 22:06:58 Could not obtain certificates:
The domain you try to get certificate for is not registered.
Could you please double check on the spelling or your domain registration status?
Thank you
I got it all working.
Basically I did the following in case others need to:
Stopped using the Lego Btinami method of install the SSL. I deleted my old SSL certs.
Installed certbot and ran certbot certonly for my four needed sites (with and without WWW).
Pointed those certs to the very strange location that Bitnami stores them and made edits to the very strange conf files that Bitnami uses.
It all worked.
Wish I never used the Bitnami stack from AWS in the first place…
Thanks for all the help.
