Setting up Letsencrypt for a single Wordpress Multisite installation with many domains? still missing something
My domain is:hlsitemanagement.com
I ran this command: certbot --apache -d hlsitemanagement.com
It produced this output:Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for hlsitemanagement.com
Waiting for verification…
We were unable to find a vhost with a ServerName or Address of hlsitemanagement.com.
Which virtual host would you like to choose?
(note: conf files with multiple vhosts are not yet supported)
1: lightningbird.com.conf | Multiple Names | | Enabled
2: 000-default.conf | | | Enabled
3: 000-default-le-ssl.conf | happylife-network.com | HTTPS | Enabled
4: hlsitemanagement.com.conf | hlsitemanagemant.com | | Enabled
Select the appropriate number [1-4] then [enter] (press ‘c’ to cancel): 4
The selected vhost would conflict with other HTTPS VirtualHosts within Apache. Please select another vhost or add ServerNames to your configuration.
VirtualHost not able to be selected.
  • Unable to install the certificate
    /etc/letsencrypt/live/hlsitemanagement.com-0001/fullchain.pem
    /etc/letsencrypt/live/hlsitemanagement.com-0001/privkey.pem
    Your cert will expire on 2018-07-12. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
My web server is (include version):apache2
The operating system my web server runs on is (include version):Ubuntu 16.04
My hosting provider, if applicable, is:digitalocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):WordPress 4.9.1
Hi, I’m just trying setup a wordpress multisite with multiple domain names, I’ve cloned the 000-default.conf in /etc/apache2/sites-available added the ServerName but im still having issues. what am i missing. Please Help
i’ve read this thread Setting up Letsencrypt for a single Wordpress Multisite installation with many domains? but still can’t get it to work
All Sites-Available configs should be "called" from Sites-Enabled
Please show all the Sites-Enabled config files.
