There is, but noting like sitesenabled in there either.
There should be an “include” or “includeoptional” line in the main httpd.conf file.
It would define the files that are to be included.
Yes, I have:
Secure (SSL/TLS) connections
Include /usr/local/etc/httpd/extra/httpd-ssl.conf
Include /usr/local/etc/httpd/extra/httpd-vhosts-le-ssl.conf
It’s obviously grabbing httpd-ssl.conf since netbracquets.com works.
Ok, then show the file:
We'll try to figure out why things are failing...
This is the whole file. I commented out the netbracquets.com part when I moved it to the main/default section of httpd-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:8443>
General setup for the virtual host
DocumentRoot “/Library/WebServer/Documents”
ServerName homebridgemania.com
ServerAdmin support@netbrackets.com
SSLCertificateFile “/etc/letsencrypt/live/homebridgemania.com/fullchain.pem”
SSLCertificateKeyFile “/etc/letsencrypt/live/homebridgemania.com/privkey.pem”
ErrorLog “/usr/local/var/log/httpd/error_log”
TransferLog “/usr/local/var/log/httpd/access_log”
</VirtualHost>
</IfModule>
#<IfModule mod_ssl.c>
#<VirtualHost *:8443>
ServerName netbracquets.com
ServerAlias www.netbracquets.com
<Directory /Library/WebServer/Documents>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Require all granted
</Directory>
#SSLCertificateFile /etc/letsencrypt/live/www.netbracquets.com/fullchain.pem
#SSLCertificateKeyFile /etc/letsencrypt/live/www.netbracquets.com/privkey.pem
#Include /etc/letsencrypt/options-ssl-apache.conf
#</VirtualHost>
#</IfModule>
I'm confused about why this is commented out.
Can you show the other file as it is now?
That’s the section for defining a vhost for netbracquets.com. I moved that into the main ssl.conf file and commented it out here.
not all lines were commented out though - seems like it now has multiple servernames, etc.
That’s the site here doing that. The stuff in bold is all commented out.
OK!
lets see the only other file left then.
It’s big. Full of comments.
remove all the commented lines (from your post)
OK, hold on a second.
Did you mean httpd-ssl.conf or httpd.conf?
Here’s httpd-ssl.conf
Listen 8443
SSLCipherSuite HIGH:MEDIUM:!MD5:!RC4:!3DES
SSLProxyCipherSuite HIGH:MEDIUM:!MD5:!RC4:!3DES
SSLHonorCipherOrder on
SSLProtocol all -SSLv3
SSLProxyProtocol all -SSLv3
SSLPassPhraseDialog builtin
SSLSessionCache “shmcb:/usr/local/var/run/httpd/ssl_scache(512000)”
SSLSessionCacheTimeout 300
<VirtualHost default:8443>
ServerName netbracquets.com:8443
SSLEngine on
<FilesMatch “.(cgi|shtml|phtml|php)$”>
SSLOptions +StdEnvVars
</FilesMatch>
<Directory “/usr/local/var/www/cgi-bin”>
</Directory>
BrowserMatch “MSIE [2-5]” \
nokeepalive ssl-unclean-shutdown \
downgrade-1.0 force-response-1.0
CustomLog “/usr/local/var/log/httpd/ssl_request_log” \
“%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x “%r” %b”
</VirtualHost>
well both I guess
but was focused on the ssl file
you can remove the port from that line
Which part covers the other name?
default didn’t come out right it has underscores before and after:
_default_
that’s OK I can read between the lines (and the missing ones too)
That was in the httpd-vhost-le-ssl.conf file
but you neutered that one - it has no vhost config anymore
