RSAKey bit size is not changing
The operating system my web server runs on is (include version):Windows
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):win-acme
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):2.2.4
I created my certificate, but the key provided is of 3072 size which is not compatible with my lb, So I changed the setting of win-acme RSAKeyBits to 2048 and started with a new cmd prompt. as new key cannot be added I renewed by cert. But the key provided by win-acme was again of 3072. Can someone guide what I might be doing wrong?
Might be worth posting a question to:win-acme/win-acme · Discussions · GitHub
You will need to show which options you are using on the command line.
