[RESOLVED] Certbot - how to specify webroot for unmatched domains?
I am using
certbot certonly --webroot --webroot-path /var/www/htdocs/webroot -w /var/www/htdocs/webroot -d example.com -w /var/www/htdocs/example1 -d example1.com -w /var/www/htdocs/example2 -d example2.com
What I get is
Using the webroot path /var/www/htdocs/example2 for all unmatched domains
So what is the point of the --webroot-path option if it is being ignored.
I would like to see
Using the webroot path /var/www/htdocs/webroot for all unmatched domains
How may I adapt my command to achieve this?
I’m not sure that I fully understand your question.
the --webroot-path applies to all the domains that follow, until there is another --webroot-path
so if you have --webroot-path /patha -d domain1 -d domain2 --webroot-path /pathb -d domain3 -d domain4 -d domain5
Then /patha will be used by domains1 & 2
/pathb will be used by domains 3,4 & 5
from the documentation
When requesting a certificate for multiple domains, each domain will use the most recently specified --webroot-path. So, for instance,
certbot certonly --webroot -w /var/www/example/ -d www.example.com -d example.com -w /var/www/other -d other.example.net -d another.other.example.net
would obtain a single certificate for all of those names, using the /var/www/example webroot directory for the first two, and /var/www/other for the second two.
Thanks a lof for having a look at my question and answering it.
Well the documentation does not tell at least in this spot that the -w option is an alias for the --webroot-path option. It verbosely explains the latter and the examples uses the first, i.e. the alias. That’s what got me off track regarding this option. :frowning:
What I wanted to know it how I can specify the webroot for unmatched domains. Indeed that was not really clear from my description. O_o
Now I can also self-answer: Since it always uses the last webroot specified the command should be:
certbot certonly --webroot -w /var/www/htdocs/example1 -d example1.com -w /var/www/htdocs/example2 -d example2.com -/var/www/htdocs/webroot -d example.com
Everything is in fluff now. :slight_smile:
The paragraph above in the documentation ...
In addition, you’ll need to specify --webroot-path or -w with the top-level directory (“web root”) containing the files served by your webserver. For example, --webroot-path /var/www/html or --webroot-path /usr/share/nginx/html are two common webroot paths.
If you’re getting a certificate for many domains at once, the plugin needs to know where each domain’s files are served from, which could potentially be a separate directory for each domain. When requesting a certificate for multiple domains, each domain will use the most recently specified --webroot-path. So, for instance,
Ah, ok. My bad. Senior moments. Still I believe that the example should use --webroot-path instead of -w, just for consistency’s sake.
