It produced this output: urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.3 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.27.0
Hi there. I’m running a number of identical Nginx configurations all of which resolve and update no problem, however this domain (Porkbun registrar and DNS server) does not seem to resolve on live. Staging (using --dry-run flag) works fine. Any tips?
An error occurred requesting a new certificate for sunstarved.co, sunstarved.design, wiki.sunstarved.co, creative.sunstarved.co, dev.sunstarved.co from Let's Encrypt : Web-based validation failed : <pre>Saving debug log to /var/log/letsencrypt/letsencrypt.log
http-01 challenge for creative.sunstarved.co
http-01 challenge for dev.sunstarved.co
http-01 challenge for sunstarved.co
http-01 challenge for sunstarved.design
http-01 challenge for wiki.sunstarved.co
Using the webroot path /home/sunstarved/public_html for all unmatched domains.
Failed authorization procedure. creative.sunstarved.co (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://sunstarved.co/.well-known/acme-challenge/hAsvyxPYO1f_C2jakmNLtjMOoizmBvdMMS-daU0u63U: Error getting validation data, sunstarved.co (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://sunstarved.co/.well-known/acme-challenge/dXgZFfle_4IKe3et-Idzv2uyNQ6_k3LVJxPDORMPn1M: Error getting validation data, dev.sunstarved.co (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://sunstarved.co/.well-known/acme-challenge/7gUEAp027hdold-VoHAtd5ijfOjf7IHQNONfANYAptI: Error getting validation data, sunstarved.design (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://sunstarved.co/.well-known/acme-challenge/Sb8JVqVAs2rO29kSrns6HPzAZ_OdQlQtvEULHyL63ZA: Error getting validation data, wiki.sunstarved.co (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://sunstarved.co/.well-known/acme-challenge/IE9qXtc8FIJGnAWF95mR92SjTPhEwAUM1WPOuqUyi90: Error getting validation data
Domain: creative.sunstarved.co
Type: connection
Detail: Fetching
Domain: sunstarved.co
Type: connection
Detail: Fetching
Domain: dev.sunstarved.co
Type: connection
Detail: Fetching
Domain: sunstarved.design
Type: connection
Detail: Fetching
Domain: wiki.sunstarved.co
Type: connection
Detail: Fetching
</pre>
Your sites are responding with HTTP redirects to URLs starting with https://sunstarved.co/, but https://sunstarved.co/ doesn’t work: Its IPv6 address is running HTTP on port 443 (the HTTPS port), so Let’s Encrypt is reporting an error.
Can you resolve that problem?
Its IPv4 address has functioning HTTPS with an expired certificate, which would be fine for this purpose.
You could also turn off the redirects. Or turn off IPv6.
Oh, that would certainly explain it! Thank you for spotting this. I’ve temporarily disabled ipv6 and renewed the cert with no problem. Was this a diagnosis using telnet? I’d have been scratching my head for ages with that.
It points to an issue in my nginx configuration for ipv6 which will be affecting all of my domains, but most are configured without AAAA records so it explains why they are functional, all of my configurations currently have two listen directives for [::]:80 and [::]:443. Sounds like I might need to change my [::]:443 directive to enable ssl using listen [::]:443 ssl; ?
