Request for IP block check
My domain is: dongjiaxi.com (trying to issue a cert for www.dongjiaxi.com using dns01 - Cloudflare)
curl https://acme-v02.api.letsencrypt.org/directory
curl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to acme-v02.api.letsencrypt.org:443
I am running cert-manager on Kubernetes (Quay) and trying to issue a cert renewal for the above domain without success. Given the above command output I was wondering if our IP address might have been blocked? The IP address is 106.14.124.26
My hosting provider, if applicable, is: Alicloud (running in Shanghai - I have verified I can reach the ACME server from another k8s cluster in the same region.)
Many thanks,
Jon
That is possible...
While we wait for that answer, please check another site (to compare):
curl https://google.com/
We aren't blocking this IP address.
Thank you. Curling google actually times out but I expect that from a server in China. I am able to curl other sites though.
Thanks for checking! The cert was actually issued overnight.
