cat /etc/apache2/sites-enabled/snackconscious.com.conf
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
ServerName snackconscious.com
ServerAlias snackconscious.com www.snackconscious.com
DocumentRoot /var/www/snackconscious.com/html/web
<Directory /var/www/snackconscious.com/html/web>
AllowOverride All
Require all granted
</Directory>
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =www.snackconscious.com
#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
<VirtualHost *:80>
ServerName staging.snackconscious.com
ServerAlias staging.snackconscious.com
ServerAdmin me@example.com
DocumentRoot /var/www/snackconscious.com/staging/web
<Directory /var/www/snackconscious.com/staging/web>
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order allow,deny
allow from all
</Directory>
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =staging.snackconscious.com
</VirtualHost>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
cat /etc/apache2/sites-enabled/snackconscious.com-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
AllowOverride All
Order allow,deny
allow from all
</Directory>
RewriteEngine on
SSLCertificateFile /etc/letsencrypt/live/snackconscious.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/snackconscious.com/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
AllowOverride All
Require all granted
</Directory>
# modules, e.g.
RewriteEngine on
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
</VirtualHost>
</IfModule>
<VirtualHost *:443>
AllowOverride All
Require all granted
</Directory>
# modules, e.g.
RewriteEngine on
</VirtualHost>
</IfModule>
