*.darknest.one
Locked out of NginxProxyMgr due to HSTS being enabled on domain. Connected to container and ran:
certbot certonly --manual --preferred-challenges dns --server https://acme-v02.api.letsencrypt.org/directory --manual-public-ip-logging-ok -d '*.darknest.one' -d darknest.one
'Renew now' option in GUI previously returning 'Internal Error'
Certbot command above returned
requested (ref: /etc/letsencrypt/renewal/npm-4.conf)
It contains these names: *.darknest.one
You requested these names for the new certificate: *.darknest.one, darknest.one.
certificate?
Confirmed and did the acme challenge, then got:
Certificate is saved at: /etc/letsencrypt/live/npm-4/fullchain.pem
Key is saved at: /etc/letsencrypt/live/npm-4/privkey.pem
This certificate expires on 2023-07-21.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See https://certbot.org/renewal-setup for instructions.
BUT The site is still reporting no SSL and a check shows that its the cert that expired already - How do I get the new cert on NGNX MGR?
NginxProxyMgr running in Docker Container
Ubuntu 22.04.2 LTS
DigitalOcean
Yes
Not any more
certbot 1.16.0
