Please use the same parameters @_az has shared. So
tcp6 0 0 :::443 :::* LISTEN 2131/apache2
should be visible.
should be visible.
hello am getting these:
IPv6 Destination Address not specified (and listening mode not selected)
We need your complete output.
hello @JuergenAuer
certbot renew
Processing /etc/letsencrypt/renewal/rinex.org.rw.conf
Cert not yet due for renewal
/etc/letsencrypt/live/rinex.org.rw/fullchain.pem expires on 2019-08-21 (skipped)
No renewals were attempted.
please help me with thatā¦
The complete output of your netstat result.
the output for netstat:
netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 rinex.org.rw:ssh 196.49.7.190:34888 ESTABLISHED
tcp 0 0 rinex.org.rw:ssh 196.49.7.190:34886 ESTABLISHED
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 2 DGRAM 8096 /var/spool/postfix/dev/log
unix 16 DGRAM 8091 /dev/log
unix 3 STREAM CONNECTED 8995
unix 3 STREAM CONNECTED 9019
unix 3 DGRAM 1863
unix 2 DGRAM 10025
unix 3 STREAM CONNECTED 3276868
unix 3 STREAM CONNECTED 8005
unix 3 STREAM CONNECTED 1918 @/com/ubuntu/upstart
unix 3 STREAM CONNECTED 8964
unix 3 STREAM CONNECTED 8977
unix 3 STREAM CONNECTED 8948
unix 3 STREAM CONNECTED 7978
unix 3 STREAM CONNECTED 9003
unix 3 STREAM CONNECTED 8968
unix 3 STREAM CONNECTED 3276867
unix 2 DGRAM 3245696
unix 3 STREAM CONNECTED 8989
unix 3 STREAM CONNECTED 9015
unix 3 STREAM CONNECTED 9007
unix 3 STREAM CONNECTED 8955
unix 3 STREAM CONNECTED 8985
unix 3 STREAM CONNECTED 8009 /var/run/dbus/system_bus_socket
unix 2 DGRAM 3273820
unix 3 STREAM CONNECTED 8961
unix 2 DGRAM 3253719
unix 3 STREAM CONNECTED 8994
unix 3 STREAM CONNECTED 8982
unix 3 STREAM CONNECTED 8945
unix 3 STREAM CONNECTED 8006
unix 3 STREAM CONNECTED 3244158
unix 3 STREAM CONNECTED 1797
unix 3 STREAM CONNECTED 8965
unix 2 DGRAM 9758
unix 3 STREAM CONNECTED 8998
unix 3 STREAM CONNECTED 9024
unix 3 STREAM CONNECTED 8949
unix 3 STREAM CONNECTED 1752 @/com/ubuntu/upstart
unix 3 STREAM CONNECTED 3244159
unix 2 DGRAM 3274013
unix 3 STREAM CONNECTED 3276876
unix 3 STREAM CONNECTED 9012
unix 3 STREAM CONNECTED 8952
unix 3 STREAM CONNECTED 8973
unix 3 STREAM CONNECTED 9016
unix 3 STREAM CONNECTED 9027
unix 3 STREAM CONNECTED 9006
unix 3 STREAM CONNECTED 8956
unix 3 STREAM CONNECTED 8986
unix 3 STREAM CONNECTED 8983
unix 3 STREAM CONNECTED 8946
unix 3 STREAM CONNECTED 8070
unix 3 STREAM CONNECTED 8997
unix 3 STREAM CONNECTED 9021
unix 3 STREAM CONNECTED 8887
unix 3 STREAM CONNECTED 8962
unix 2 STREAM CONNECTED 3245694
unix 3 STREAM CONNECTED 8979
unix 3 STREAM CONNECTED 8939
unix 3 STREAM CONNECTED 9001
unix 3 STREAM CONNECTED 9025
unix 3 STREAM CONNECTED 1827
unix 3 STREAM CONNECTED 3245437 /var/run/dbus/system_bus_socket
unix 2 DGRAM 9669
unix 3 STREAM CONNECTED 8953
unix 3 STREAM CONNECTED 8941
unix 3 STREAM CONNECTED 8991
unix 3 STREAM CONNECTED 9013
unix 3 STREAM CONNECTED 8970
unix 3 STREAM CONNECTED 8942
unix 3 STREAM CONNECTED 8888 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 8376 @/com/ubuntu/upstart
unix 3 STREAM CONNECTED 9028
unix 3 STREAM CONNECTED 9009
unix 3 STREAM CONNECTED 8974
unix 3 STREAM CONNECTED 1981 /var/run/dbus/system_bus_socket
unix 3 STREAM CONNECTED 8959
unix 3 DGRAM 1864
unix 2 DGRAM 10042
unix 3 STREAM CONNECTED 3276877 /var/run/dbus/system_bus_socket
unix 2 STREAM CONNECTED 3274002
unix 3 STREAM CONNECTED 9022
unix 3 STREAM CONNECTED 8980
unix 2 DGRAM 3274004
unix 2 DGRAM 8916
unix 3 STREAM CONNECTED 3245436
unix 3 STREAM CONNECTED 8967
unix 3 STREAM CONNECTED 9000
unix 3 STREAM CONNECTED 8976
unix 3 STREAM CONNECTED 8361
unix 3 STREAM CONNECTED 9010
unix 3 STREAM CONNECTED 8992
unix 3 STREAM CONNECTED 8971
unix 2 DGRAM 3245353
unix 3 STREAM CONNECTED 9004
unix 3 STREAM CONNECTED 8958
unix 3 STREAM CONNECTED 8938
unix 2 DGRAM 9032
unix 3 STREAM CONNECTED 8988
unix 2 DGRAM 3245704
unix 3 STREAM CONNECTED 9018
unix 2 DGRAM 8742
Please read the earlier topic:
netstat -tlnp
is required.
here is the output of netsat -tlnp:
netstat -tlnp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 995/sshd
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 1183/master
tcp 0 0 0.0.0.0:5666 0.0.0.0:* LISTEN 997/xinetd
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 1068/mysqld
tcp6 0 0 :::80 :::* LISTEN 8062/apache2
tcp6 0 0 :::22 :::* LISTEN 995/sshd
tcp6 0 0 :::25 :::* LISTEN 1183/master
tcp6 0 0 :::443 :::* LISTEN 8062/apache2
Can you help me to renew my certificate for unajmiiznajmi.me
My domain is: unajmiiznajmi.me
My web server is (include version): I use Sharedhosting on menet.me hosting reseller with shared IP address 5.100.154.160
The operating system my web server runs on is (include version): Linux shared hosting
My hosting provider, if applicable, is: Menet.me
I can login to a root shell on my machine (yes or no, or I donāt know): I donāt know
Iām using a control panel to manage my site (no, or provide the name and version of the control panel): Cpanel 78.0.20
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youāre using Certbot):
Thanks in advance.
Run it as root / sudo. And add e
hereās the output netstat -tlnp:e
sudo netstat -tlnp :e
tcp6 0 0 :::80 :::* LISTEN 16569/apache2
tcp6 0 0 :::443 :::* LISTEN 16569/apache2
No, please read the documentation.
sudo netstat -tlnpe
hereās the output :sudo netstat -tlnpe:
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 8830 1011/sshd
tcp 0 0 0.0.0.0:25 0.0.0.0:* LISTEN 0 9921 1191/master
tcp 0 0 0.0.0.0:5666 0.0.0.0:* LISTEN 0 8860 1013/xinetd
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 107 9087 1074/mysqld
tcp6 0 0 :::80 :::* LISTEN 0 10733 1868/apache2
tcp6 0 0 :::22 :::* LISTEN 0 8832 1011/sshd
tcp6 0 0 :::25 :::* LISTEN 0 9922 1191/master
tcp6 0 0 :::443 :::* LISTEN 0 10737 1868/apache2
where can i find documentation.
Possibly unrelated (but possibly related), Ubuntu 14.04 has been offically out of support and cut off from security updates without a paid subscription since April. 14.04.5 isnāt even the last release, that would be .6. Itās sometimes an enormous pain to transition servers, but it might be time to start fresh with a new image; that might magically fix your LE issues, or it might not, but itāll certainly keep you safer online.
