Renewal 404 fail
I removed those entries and now my site appears to be working. Certbot still not able to renew though.
Trying on lukehero.com
A couple of days ago this site worked just fine and all my sites have been running with IPv6 with no issues, not sure what has changed to cause this.
There is the ipv6.
Checked now:
lukehero.com A 173.255.202.118 yes 1 0
AAAA 2600:3c00::f03c:91ff:feb8:11d3 yes
www.lukehero.com A 173.255.202.118 yes 1 0
Linode takes a while to apply DNS changes - your IPv6 address is still present.
One left field fix you can try in each server:
listen 80;
listen [::]:80;
Based on the theory that nginx is not properly routing the virtualhosts for IPv6 sockets.
Oh, that's terrible:
Domain: lukehero.com
Primary: ns1.linode.com
Mail: heyluke.pm.me
Serial: 2019022330
Refresh: 14400
Retry: 14400
Expire: 1209600
TTL: 86400
It appears that I can now renew my certs since doing this. Even on sites with IPv6 still enabled.
Now your ipv6 is gone.
AAAA yes
AAAA yes
And you have a new certificate:
CN=lukehero.com
	24.02.2019
	25.05.2019
expires in 90 days	lukehero.com - 1 entry
But you have both dns entries (www and non-www). So you should create one certificate with both domain names and use that.
Currently, your www version is insecure:
http://lukehero.com/
173.255.202.118 301 https://lukehero.com/ 0.300 A
http://www.lukehero.com/
173.255.202.118 404 0.293 M
Not Found
173.255.202.118 200 6.694 B
https://www.lukehero.com/
173.255.202.118 200 6.440 N
Certificate error: RemoteCertificateNameMismatch
I shall remove the www from my dns.
It looks like things are working now since adding the listen [::]:80; to my sites-enabled files.
Yep, you have two options:
  • Remove the www dns entry
  • create one certificate with the www and non-www domain name and add correct redirects
If it is a domain, (2) is preferred. If it is a subdomain, www.+ subdomain isn't really required.
Thank you immensely @_az and @JuergenAuer I am very grateful for your help with this.
