Renew works from command line but not from system crontab
My domain is: admin.kalkulisto.net
I ran this command: /home/baby/soft/letsencrypt/certbot-auto renew --noninteractive (from system crontab)
2016-07-19 03:41:02,945:WARNING:certbot.renewal:Attempting to renew cert from /etc/letsencrypt/renewal/admin.kalkulisto.net.conf produced an unexpected error: The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(). Skipping.
My operating system is (include version): Ubuntu Server 14.04.4
My web server is (include version): Apache 2.4.7-1ubuntu4.9
My hosting provider, if applicable, is: linode
Hi. I added a simple file in /etc/cron.d called letsencrypt-certbot_renew-all in order to automatically renew the certificates about to expire once a month.
The only line in the crontab file looks like:
41 3 19 * * root /home/baby/soft/letsencrypt/certbot-auto renew --noninteractive
That is, run the script as root every 19th of the month at 3:41.
However, whenever there IS a renewable ceritifcate, I get a message with this error from crontab:
Processing /etc/letsencrypt/renewal/totales.com.ar.conf
Processing /etc/letsencrypt/renewal/admin.kalkulisto.net.conf
Processing /etc/letsencrypt/renewal/123-probando.kalkulisto.com.conf
  /etc/letsencrypt/live/totales.com.ar/fullchain.pem (skipped)
  /etc/letsencrypt/live/123-probando.kalkulisto.com/fullchain.pem (skipped)
  /etc/letsencrypt/live/admin.kalkulisto.net/fullchain.pem (failure)
It seems to imply that the apache plugin is not installed (which it is). In fact, after getting the message I log in as root (sudo -i), run the EXACT same command and it works like a charm:
root@abako:/etc/cron.d# /home/baby/soft/letsencrypt/certbot-auto renew --noninteractive
new certificate deployed with reload of apache server; fullchain is
  /etc/letsencrypt/live/admin.kalkulisto.net/fullchain.pem (success)
I think there may be something missing in the environment but I don’t know what.
Very common cause here is inadequate PATH variable in the cron environment. You could spend a while figuring out exactly what path elements are important, but a shortcut is to type
printenv PATH
in the environment where it works, and copy that value into a new PATH variable (or replacing an old one) at the top of the cron file
PATH=/blah/blah:/more/things/that/you/got/from/printenv
NB Don’t just copy what I wrote - it’s nonsense, you need to copy from a working value of PATH
I can’t guarantee that’s the problem, but there’s a good chance.
Thank you. Gonna try it.
