My domain are 18 domains, wtrade.com i the first
I ran this command: running win-acme.v2.1.19.1142.x64
It produced this output: (see at the end)
My web server is (include version): IIS however I hope is not used
The operating system my web server runs on is (include version): Windows Server 2019
My hosting provider, if applicable, is: None
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Application use powershell
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): not sure
The process was able to check correctly all domains against DNS, however after end of each verification
[DBUG] [*.drximenaflanders.com] Preliminary validation from 23.126.143.86 looks good
I get the following message (one for each domain)
[VERB] Request completed with status OK
** [EROR] [.drximenaflanders.com] Authorization result: invalid**
** [EROR] [.drximenaflanders.com] {**
** "type": "urn:ietf:params:acme:error:dns",**
** "detail": "DNS problem: NXDOMAIN looking up TXT for _acme-challenge.drximenaflanders.com - check that a DNS record exists for**
is there any additional DNS record required ?
[DBUG] [.drximenaflanders.com] Looking for TXT value OVN33LyeW4ie9Qr24yOprxFmhyFld0CTLyUgwekU-n4...
[DBUG] [.drximenaflanders.com] Preliminary validation asking 108.248.7.231...
[DBUG] [.drximenaflanders.com] Preliminary validation from 108.248.7.231 looks good
[DBUG] [.drximenaflanders.com] Preliminary validation asking 52.91.162.105...
[DBUG] [.drximenaflanders.com] Preliminary validation from 52.91.162.105 looks good
[DBUG] [.drximenaflanders.com] Preliminary validation asking 23.126.143.86...
[DBUG] [.drximenaflanders.com] Preliminary validation from 23.126.143.86 looks good
[DBUG] [.drximenaflanders.com] Preliminary validation asking 52.86.234.215...
[DBUG] [.drximenaflanders.com] Preliminary validation from 52.86.234.215 looks good
[INFO] [.drximenaflanders.com] Preliminary validation succeeded
[VERB] Commit was successful
[DBUG] [.drximenaflanders.com] Submitting challenge answer
[DBUG] Send POST request to https://acme-v02.api.letsencrypt.org/acme/chall-v3/369212932617/bSN33Q
[DBUG] Refreshing authorization (1/15)
[EROR] [*.drximenaflanders.com] {
this domain",
"status": 400
[VERB] Starting post-validation cleanup
[INFO] Script C:\Repos\win-acme.v2.1.19.1142.x64.pluggable\Scripts\microsoft-dns.ps1 starting with parameters delete drximenafl
anders.com _acme-challenge.drximenaflanders.com OVN33LyeW4ie9Qr24yOprxFmhyFld0CTLyUgwekU-n4
[DBUG] Process launched: powershell.exe (ID: 14804)
[VERB] Waiting for process to finish...
[VERB] Process output without data received
[VERB] Process error without data received
[INFO] Script finished
[VERB] Post-validation cleanup was succesfull
