Renew fail, tls-sni-01 challenge, How do fix?
certbot-auto renew is fail.
https://115.68.27.104:443 is well working.
what is problem? how to fix this problem?
log is below:
root@ubuntu:/home/ash84# ./certbot-auto --nginx
1: ash84.net
blank to select all options shown (Enter ‘c’ to cancel): 1
tls-sni-01 challenge for ash84.net
Waiting for verification…
Failed authorization procedure. ash84.net (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 1a2ad416196e61a755462be530666190.983a48b7f372cb1fd6c0e4ca4ab863f1.acme.invalid from 115.68.27.104:443. Received 2 certificate(s), first certificate had names “ash84.net”
    Domain: ash84.net
    Detail: Incorrect validation certificate for tls-sni-01 challenge.
    Requested
Not sure what the problem is - you might try upgrading the certbot client.
And since http is also allowed to your site, you might want to try
certbot-auto --webroot /path/to/your/web/files
instead of
certbot-auto --nginx.
Hi @AhnSeongHyun,
Do you know what command you originally used to obtain this certificate? Did you try ./certbot-auto renew for it?
Unfortunately, I don't think that will help in this case because certbot-auto does so automatically every time that it's run, differently from OS-packaged versions of Certbot.
renew command raise error about binding 443 port.
but https://115.68.27.104:443 is working.
root@ubuntu:/home/ash84# ./certbot-auto renew
Processing /etc/letsencrypt/renewal/ash84.net.conf
Attempting to renew cert (ash84.net) from /etc/letsencrypt/renewal/ash84.net.conf produced an unexpected error: Problem binding to port 443: Could not bind to IPv4 or IPv6… Skipping.
/etc/letsencrypt/live/ash84.net/fullchain.pem (failure)
Try:
certbot renew --pre-hook “service nginx stop” --post-hook “service nginx start”
@AhnSeongHyun, as I think @rg305 just deduced, it sounds like you use --standalone when you originally obtained the certificate! Do you know if you did that, and, if so, how you chose that method?
Could you please post the contents of the file /etc/letsencrypt/renewal/ash84.net.conf?
# renew_before_expiry = 30 days version = 0.13.0 cert = /etc/letsencrypt/live/ash84.net/cert.pem privkey = /etc/letsencrypt/live/ash84.net/privkey.pem chain = /etc/letsencrypt/live/ash84.net/chain.pem fullchain = /etc/letsencrypt/live/ash84.net/fullchain.pem archive_dir = /etc/letsencrypt/archive/ash84.net
#Options used in the renewal process
[renewalparams]
authenticator = standalone
installer = None
account = 23c6261f42d37b9ac301ae5174906045
Thanks for posting it!
So, I would like to know how you chose to use --standalone. I don’t think it’s usually the best choice for most users.
@rg305 is right that you need to use something right
if you want to renew using this authentication method, because it conflicts with a running nginx process, since it wants to independently take over the use of port 443.
