Removal of Client EKU Clarification
I use LetsEncrypt certificates for a webserver performing mTLS authentication.
I simply want to clarify/confirm my understanding of the changes from:
Ending TLS Client Authentication Certificate Support in 2026
"if you use Let’s Encrypt certificates as client certificates to authenticate to a server, this change may impact you.".
I'm assuming that my use case is not affected, as LE certs are only ever used as the server side certificate in a given connection.
Can someone from LE confirm?
Correct.
mTLS is only affected if you're using Let's Encrypt certificates on the client side. But usually the client certificate is issued by a private CA.
