Webuzo does, but it doesn’t work. It can never find the certs even though it puts them on the server, so you have to renew them yourself then copy and paste all three parts for every domain name. It’s ridiculous.
Here’s what I got on the last dry run I ran.
[root@stanragets webuzo]# certbot renew --dry-run
Processing /etc/letsencrypt/renewal/d.stanragets.com.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
http-01 challenge for d.stanragets.com
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/d.stanragets.com.conf produced an unexpected error: Failed authorization procedure. d.stanragets.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up CAA for d.stanragets.com. Skipping.
Processing /etc/letsencrypt/renewal/design.stanragets.com.conf
http-01 challenge for design.stanragets.com
http-01 challenge for fineart.stanragets.com
Attempting to renew cert from /etc/letsencrypt/renewal/design.stanragets.com.conf produced an unexpected error: Failed authorization procedure. design.stanragets.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up CAA for design.stanragets.com, fineart.stanragets.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up CAA for fineart.stanragets.com. Skipping.
Processing /etc/letsencrypt/renewal/fineart.stanragets.com.conf
Attempting to renew cert from /etc/letsencrypt/renewal/fineart.stanragets.com.conf produced an unexpected error: Failed authorization procedure. fineart.stanragets.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: SERVFAIL looking up CAA for fineart.stanragets.com. Skipping.
Processing /etc/letsencrypt/renewal/stanragets.com.conf
http-01 challenge for stanragets.com
http-01 challenge for www.stanragets.com
Attempting to renew cert from /etc/letsencrypt/renewal/stanragets.com.conf produced an unexpected error: Failed authorization procedure. stanragets.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://stanragets.com/.well-known/acme-challenge/kyuM5cZzQU1_ivJdOe0u4Iuu0pX7r9qJqubZOGKtW9w: "
<meta name="viewport" content="width=device-width, initial-s", www.stanragets.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.stanragets.com/.well-known/acme-challenge/9qfpJWJxCWW3Lm7Z568kayeBfgzvMQnt0-iaEIIbfCw: "
<meta name="viewport" content="width=device-width, initial-s". Skipping.
/etc/letsencrypt/live/d.stanragets.com/fullchain.pem (failure)
/etc/letsencrypt/live/design.stanragets.com/fullchain.pem (failure)
/etc/letsencrypt/live/fineart.stanragets.com/fullchain.pem (failure)
/etc/letsencrypt/live/stanragets.com/fullchain.pem (failure)
4 renew failure(s), 0 parse failure(s)
Domain: d.stanragets.com
Type: connection
Detail: DNS problem: SERVFAIL looking up CAA for d.stanragets.com
Domain: design.stanragets.com
Type: connection
Domain: fineart.stanragets.com
Type: connection
Type: connection
Domain: stanragets.com
Detail: Invalid response from
Domain: www.stanragets.com
