ollykeeling.me
sudo certbot --authenticator standalone --installer nginx --pre-hook “service nginx stop” --post-hook “service nginx start”
Running pre-hook command: service nginx stop
http-01 challenge for ollykeeling.me
Waiting for verification…
Running post-hook command: service nginx start
Failed authorization procedure. ollykeeling.me (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://ollykeeling.me/.well-known/acme-challenge/g6EhSSsP_hshfe9IfKigqP0t-7JfjKntYrt1Nfg0IEo [212.159.105.9]: "\n\n<html xmlns=“http”
Domain: ollykeeling.me
Detail: Invalid response from
xmlns=“http”To fix these errors, please make sure that your domain name was
nginx/1.14.2
Raspberry Pi OS (buster)
GoDaddy
Yes
No
0.31.0
/etc/nginx/sites-available/ollykeeling.me
listen 80 default_server;
root /var/www/html;
index index.htm index.html;
server_name ollykeeling.me;
include snippets/letsencrypt.conf;
This is symlinked to /etc/nginx/sites-enabled
Root website is var/www/html/
/etc/nginx/snippets/letsencrypt.conf
location ^~ /.well-known/acme-challenge/ {
allow all;
root /var/lib/letsencrypt/;
default_type “text/plain”;
try_files $uri =404;
location ~ /.well-known {
allow all;
I have tried a number of things to date so the letsencrypt log file is quite long, but I can post that if needed
