And here is the 000-default-le-ssl.conf:
<IfModule mod_ssl.c>
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
#EIGENS VON LUCAS EEKHOF HINZUGEFUEGT:
<Directory "/var/www/html/privateusers/lucas">
AuthType Basic
AuthName "lucas"
AuthUserFile /etc/apache2/.htpasswd
Require valid-user
</Directory>
ServerName eekhof.org
ServerAlias www.eekhof.org
SSLCertificateFile /etc/letsencrypt/live/eekhof.org/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/eekhof.org/privkey.pem
</VirtualHost>
</IfModule>
<VirtualHost *:80>
# modules, e.g.
AuthType Basic
AuthName "lucas"
Require valid-user
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.eekhof.org [OR]
RewriteCond %{SERVER_NAME} =eekhof.org
</VirtualHost>
</IfModule>
<VirtualHost *:80>
# modules, e.g.
AuthType Basic
AuthName "lucas"
Require valid-user
</Directory>
RewriteEngine on
</VirtualHost>
</IfModule>
