I’m tearing my hair out here but might be missing something. I have been setting up a web site on a new server and have successfully installed and activated Letsencrypt on a sub-domain of the one we want to end up with: test.orders.topshelfsupplyco.com.au. That worked and works fine.
Today I went to set up the desired domain: orders.topshelfsupplyco.com.au and I keep getting the “query timed out looking up CAA for orders.topshelfsupplyco.com.au” error.
I cannot understand because it happily set up test.orders.topshelfsupplyco.com.au. So orders.topshelfsupplyco.com.au is just running on http for now.
My domain is: orders.topshelfsupplyco.com.au
I ran this command: several. I started with letsencrypt --apache -d test.orders.topshelfsupplyco.com.au to do the original one. Then I did the same but added the additional domain:
letsencrypt --apache -d orders.topshelfsupplyco.com.au -d test.orders.topshelfsupplyco.com.au
I then resorted to letsencrypt --apache and walked through the wizard. I can happily renew the test domain, but not register the non-test domain
Failed authorization procedure. orders.topshelfsupplyco.com.au (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: query timed out looking up CAA for orders.topshelfsupplyco.com.au
Domain: orders.topshelfsupplyco.com.au
Type: connection
Detail: DNS problem: query timed out looking up CAA for
etc…
Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-36-generic x86_64)
Apache/2.4.18 (Ubuntu)
My hosting provider, if applicable, is: www.dctwo.com.au, this is a virtual server (VPS?)
Thanks
