My domain is: elvenware.com, elven.work
I ran this command: sudo certbot --nginx
It produced this output: Which names would you like to activate HTTPS for?
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: elven.work
2: www.elven.work
3: www.elvenare.com
4: elvenware.com
Requesting a certificate for elven.work and 3 more domains
Domain: www.elvenare.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.elvenare.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.elvenare.com - check that a DNS record exists for this domain
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
My hosting provider, if applicable, is: aws ec2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
I can create a certificate for elven.work. But when I tried to create it for all 4 URLS, the command failed as shown above. After trying all 4, I tried again asking only for the two associated with elven.work. That succeeded. But now I'm set up to work with only half my urls, and elvenware.com is more important than elven.work.
So I have two questions. Why does it succeed for elven.work and fail for elvenware.com? What is the best way to add elvenware.com assuming I can get it to work.
I called up network solutions to ask if I had filled in the A record for elvenware.com correctly and they assured me that I had.
