Problema al renovar un certificado
My domain is: facturar.vicens.com
I ran this command: certbot
blank to select all options shown (Enter 'c' to cancel): 14
Requesting a certificate for facturar.vicens.com
  Domain: facturar.vicens.com
  Type:   unauthorized
  Detail: 2a00:1d70:c01c::71:130: Invalid response from http://facturar.vicens.com/.well-known/acme-challenge/7_6iQ38ooAoQcjy5l8UwBY704eJpk3YguykPz9_OUng: "<br />\n<b>Fatal error</b>:  Uncaught Error: Call to undefined function mysql_error() in /furanet/sites/vicens.com/web/htdocs/wp-"
My web server is (include version): Apache/2.4.38 (Debian)
The operating system my web server runs on is (include version): Debian 10
My hosting provider, if applicable, is: ionos
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
certbot 2.8.0
Welcome @nabil12
It looks like your IPv6 address points to a different server than your IPv4 address. Check that your DNS A and AAAA IP addresses match your respective public IP's. Use the https://letsdebug.net test site after making changes.
curl -i4 http://facturar.vicens.com
HTTP/1.1 302 Moved Temporarily
Server: Apache/2.4.38 (Debian)
curl -i6 http://facturar.vicens.com
HTTP/1.1 200 OK
Server: Apache
<br />
<b>Fatal error</b>:
Uncaught Error: Call to undefined function mysql_error() in /furanet/sites/vicens.com/web/htdocs/wp-content/plugins/revslider/inc_php/framework/db.class.php:29
It seems like they are on completely different ISPs too.
Using the online tool Let's Debug now yields these results https://letsdebug.net/facturar.vicens.com/1746243
