I ran this command: certbot --authenticator standalone --installer nginx -d hungryseason.com --pre-hook “service nginx stop” --post-hook “service nginx start”
Plugins selected: Authenticator standalone, Installer nginx
Running pre-hook command: service nginx stop
http-01 challenge for hungryseason.com
Waiting for verification…
Running post-hook command: service nginx start
Failed authorization procedure. hungryseason.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://hungryseason.com/.well-known/acme-challenge/I-arw2OvcXOylHrJryb4Ceh-mT5MNrEoSC2YP30ukB4: Timeout
My web server is (include version): nginx service ver. 0.91-ubuntu1
The operating system my web server runs on is (include version): 16.04
My hosting provider, if applicable, is: DigitalOcean
You have an AAAA record but your server is not reachable over IPv6. Let’s Encrypt uses IPv6 for validation if you have an AAAA record so you need to either fix it or remove it.
(of course it’s nginx that can’t be reached right now, but I’m guessing certbot will have the same problem)
It’s a record in your DNS. The A record points to your IPv4 address and the AAAA record points to your IPv6 address. If you don’t know how to fix it you can probably go into your DNS settings and remove it.
While this is technically true, it's also important to meet people where they are at. For instance, based on @96andi's question "What is AAAA?" you can probably guess that they would need to learn a lot about IPv6 and Internet routing to be able to diagnose and fix any issues they are having, and that man ip6tables is not sufficient guidance. I think in this situation, the most appropriate advice is "Visit your DNS provider's control panel and remove any AAAA records," with perhaps a link to a useful introduction to IPv6 if they want to learn more (sorry I don't have one handy).
Do not modify the A record as that seems to be correct already.
You can remove the AAAA record entirely.
You said you’re on Digital Ocean, so if you want to try to fix IPv6 rather than removing it, I suppose their tutorials might be helpful? But removing the AAAA record should be sufficient to make Let’s Encrypt work (assuming of course that there are no other issues). You can recreate it later, when and if you’re confident that you have IPv6 working correctly.
