Problem with renewing certificate with certbot on centos-6 (Apache 2 issue?)
Hello,
Thanks for writing this software - I’m pretty sure that my issue reflects my lack of understanding of some relatively basic aspect of the functionality. Until September 9th I had a working certificate, but then it expired.
My domain is: www.ocollector.org & ocollector.org
I ran this command: certbot-auto --apache -d www.ocollector.org -d ocollector.org
It produced this output: The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(‘Could not find configuration root’,)
My web server is (include version): Apache 2
The operating system my web server runs on is (include version): Centos 6
My hosting provider, if applicable, is: ecowebhosting (but VPS)
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): sometimes, but not for SSL certificate management
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.38.0
Based on the error message and what I saw on other threads I also tried
I ran this command: certbot-auto --apache -d www.ocollector.org --apache-server-root /etc/apache2
http-01 challenge for www.ocollector.org
File: /etc/httpd/conf.d/le_http_01_challenge_pre.conf - Could not be found to be deleted
  • Certbot probably shut down unexpectedly
    File: /etc/httpd/conf.d/le_http_01_challenge_post.conf - Could not be found to be deleted
    An unexpected error occurred:
    File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in
    load_entry_point(‘letsencrypt==0.7.0’, ‘console_scripts’, ‘letsencrypt’)()
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/main.py”, line 1378, in main
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/main.py”, line 1133, in run
    certname, lineage)
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/main.py”, line 121, in _get_and_save_cert
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/client.py”, line 405, in obtain_and_enroll_certificate
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/client.py”, line 348, in obtain_certificate
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/client.py”, line 384, in _get_order_and_authorizations
    authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot/auth_handler.py”, line 69, in handle_authorizations
    resps = self.auth.perform(achalls)
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/configurator.py”, line 2304, in perform
    http_response = http_doer.perform()
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/http_01.py”, line 76, in perform
    self._mod_config()
    File “/opt/eff.org/certbot/venv/lib64/python3.4/site-packages/certbot_apache/http_01.py”, line 134, in _mod_config
    with open(self.challenge_conf_pre, “w”) as new_conf:
    FileNotFoundError: [Errno 2] No such file or directory: ‘/etc/httpd/conf.d/le_http_01_challenge_pre.conf’
So I’m inclined to think there’s a problem with Apache interacting with certbot-auto?
Thanks in advance for any help,
Ant
Hi @anthonyhaffey
that's
the standard value. So if your command doesn't work without that parameter, it can't work with that parameter.
Please check your system to find your real httpd root.
Google shows something like
By default, modules are located in the /etc/httpd/modules/ directory . Configuration directives for the default modules are located in /etc/httpd/ conf /httpd. conf , while configuration options for optional modules installed with yum are generally placed in . conf files in /etc/httpd/ conf .d/
but you may have a different configuration.
Thanks, very helpful reply. I was able to find the correct location which in my case required me to update my command to:
certbot-auto --apache -d www.ocollector.org --apache-server-root /opt/eff.org/certbot/venv/lib/python3.4/site-packages/certbot_apache/tests/testdata/gentoo_apache/apache/apache2/
Just checked www.ocollector.org, the certificate is working now.
Thanks again for your help.
Oh, that's
really a non standard path.
Happy to read that you have found that special path :+1:
