Problem with renewal: Incorrect validation certificate for tls-sni-01 challenge
Also having a problem with renewal:
   Domain: www.paulbeard.org
   Type:   unauthorized
   Detail: Incorrect validation certificate for tls-sni-01 challenge.
   Requested
   08175ba7a90cf7c6383b718dcd515e20.26c75cf64cc1ae7c029e7e8f3130d55c.acme.invalid
   from 73.225.76.58:443. Received 2 certificate(s), first certificate
   had names "cloud.paulbeard.org, paulbeard.org, www.paulbeard.org"
   Domain: cloud.paulbeard.org
   Type:   unauthorized
   Requested
   45bf74bdca64a305975a75e4bd48c788.eff6ed0ad95ae8bec52ccfd3edc69b43.acme.invalid
   Domain: paulbeard.org
   Type:   unauthorized
   Requested
   7369f2dd7e09e7d5d31c6dec79894b89.291e4b2ea69102035ebce2988c5d1acd.acme.invalid
This is what dig knows:
dig www.paulbeard.org any
; <<>> DiG 9.8.7 <<>> www.paulbeard.org any
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 28484
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;www.paulbeard.org.             IN      ANY
;; ANSWER SECTION:
www.paulbeard.org.      300     IN      AAAA    2001:470:b:839:a00:27ff:fe5c:8bcb
www.paulbeard.org.      300     IN      A       73.225.76.58
;; Query time: 323 msec
;; SERVER: 192.168.0.1#53(192.168.0.1)
;; WHEN: Mon Jan 01 17:44:35 PST 2018
;; MSG SIZE  rcvd: 79
I’ve split this post into a new thread; the root cause is probably not exactly the same, so it’s easier to work on it separately. :slightly_smiling_face:
Could you fill out the information below?
No problem: I was wary of starting a new thread.
Hm… How is that set up? Certbot is using the standalone authenticator, which means it listens on port 443 (by default), but Nginx is already listening on port 443. It should fail with an error or something.
Related, I’m not sure the standalone plugin works well on IPv6, especially if it’s an older version of Certbot, especially on FreeBSD. But it might be fine.
I don’t know if IPv6 is the problem. I did verify that there are AAAA records but it’s not like it works and I can’t be bothered to figure it out.
certbot should be up to date. the nginx plugin isn’t there yet but the standalone version has worked for quite some time.
I wrap it in a script:
more /usr/local/bin/certbot.sh
#!/usr/local/bin/bash
export INTERVAL=/usr/bin/jot -r 1 1 3599
logger "certbot sleeping $INTERVAL seconds"
sleep $INTERVAL
/usr/sbin/service nginx stop
/usr/local/bin/certbot renew
/usr/sbin/service nginx start
logger “certbot renewal complete”
Bah. Looks like it works. It fails on the dry-run when it can’t use port 443. If I kill nginx, then run it, it works fine.
tls-sni-01 challenge for paulbeard.org
tls-sni-01 challenge for cloud.paulbeard.org
tls-sni-01 challenge for www.paulbeard.org
new certificate deployed without reload, fullchain is
/usr/local/etc/letsencrypt/live/paulbeard.org/fullchain.pem
**          (The test certificates below have not been saved.)
  /usr/local/etc/letsencrypt/live/paulbeard.org/fullchain.pem (success)
**          (The test certificates above have not been saved.)
