Hi everyone,
I got a problem with installing let’s encrypt on my tomcat server on Centos 7.
I ran the following commands to install the necessary programs:
sudo yum -y install epel-release
sudo yum -y install certbot
After that I stopped tomcat and forwarded the ssl port using these commands
sudo systemctl stop tomcat
sudo firewall-cmd --add-forward-port=port=443:proto=tcp:toport=8443 --permanent
systemctl restart firewalld
Then I generated the certifcate:
sudo keytool -genkey -alias tomcat -keyalg RSA -keystore /opt/tomcat/.keystore -keysize 2048
sudo keytool -certreq -alias tomcat -file request.csr -keystore /opt/tomcat/.keystore
sudo certbot certonly --csr request.csr
When I want to add the file to the keystore, it goes wrong.
sudo keytool -import -trustcacerts -alias tomcat -file 0000_chain.pem -keystore /opt/tomcat/.keystore
I need to enter my keystore password, but it always gives me the following error:
keytool error: java.lang.Exception: Public keys in reply and keystore don't match
Hope somebody can help me, I’m really a noob with ssl certificates.
rg305
August 9, 2017, 3:02pm
2
Have you previously used the alias “tomcat”?
If so, try a new alias - tomcat2
Thanx for the fast reply!
I tried it with another alias, but I still got the same error.
Thanx !
rg305
August 9, 2017, 4:07pm
4
I think you may need to add the root ca first before adding the 0000_chain.pem
Can you tell me how I do that ?
Sorry I never worked with Let’s encrypt before and I have really no clue.
Thanx !
rg305
August 9, 2017, 4:34pm
6
Try:
sudo keytool -import -trustcacerts -alias tomcat -file 0000_fullchain.pem -keystore /opt/tomcat/.keystore
schoen
August 9, 2017, 4:53pm
7
There are some previous forum posts that might help, like
rg305:
0000_fullchain.pem
I have no file called 0000_fullchain.pem
rg305
August 9, 2017, 9:00pm
9
what other files are near 0000_chain.pem
i believe the trustedcacerts is for intermediates not the cert itself
you should use -importcert
let me know the output of
sudo keytool -importcert -alias tomcat -file 0000_chain.pem -keystore /opt/tomcat/.keystore
Andrei
Thanx for the answer, when I run this I get
I also have the following files:
0000_cert.pem
0000_chain.pem
0001_chain.pem
