HELP
Domain: www.rsoluciones.nat.cu
Detail: 190.92.127.206: Invalid response from http://www.rsoluciones.nat.cu/.well-known/acme-challenge/8CQwgLfjEJPtBUVgDx6zQokMeD14LCzaXh-s1ZsidVo : "function G(str){return document.getElementById(str);}function C(){P.value='';P.name=P.name.substr(0,17)+"CG""
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
@rodascu I've moved your post in the other thread to its own thread in the #help section. Please don't "hijack" other threads for an issue you're having which is not related.
In the #help section you would have been shown a questionnaire which is mandatory to fill out. I'll post it below. Please answer all the questions to the best of your knowledge:
Detail: 190.92.127.206: Invalid response from http://www.rsoluciones.nat.cu/.well-known/acme-challenge/EVMF7_OX92au83kVoJUngfijzkvIQREZfqBZEgOCrYc: "function G(str){return document.getElementById(str);}function C(){P.value='';P.name=P.name.substr(0,17)+"CG""
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
Let's keep everything clean and simple in this thread where I originally moved the posts into in the first place
@rodascu Please post the answers to the questionnaire in this thread publicly instead of in a direct message to me That way everyone can help in solving your issue.
@rodascu, this looks like you might have an anti-bot tool enabled either on your web server or in a web application firewall (WAF), in order to limit the ability of bots to connect to your site.
Let's Encrypt normally needs to use bots to connect to (part of) your site in order to confirm that you control the domain name for which you're requesting a certificate.
If you use scripts to prevent these bots from connecting, the certificate authority can't complete the validation process.
