I realize this is a common question and I am sorry that despite reading a ton of related threads, I am still unable to resolve my problem.
They used to renew when I was on Ubuntu 16.04, but after upgrading to 18.04 failed, I was forced to reformat the disk and redo everything from scratch.
Currently using WordPress 4.9.8 on my sites.
OS: Ubuntu 18.04.1 with latest updates as of 08:00 GMT 11-Dec-2018
certbot: 0.26.1
apache2: 2.4.29
I am (fairly) certain certbot renew --dry-run worked back in September 2018.
I use Cloudflare. I verified that the SSL option is set to ‘Full SSL (strict)’
The ‘authenticator’ is set to ‘apache’ in my /renewal/conf file
I did not have an ‘acme-challenge’ directory, so I created one. I set the ownership to ‘www-data:www-data’ and the permissions to 777 (not happy about that).
I added the file ‘goodbye’ to the folder to ensure it could be accessed.
I also added a ‘.htaccess’ to turn the ‘RewriteEngine’ off in that folder.
Around 08:00 GMT 11-Dec-2018, I also added an ‘AAAA’ record to point to my ip6 address.
Executing: certbot renew --dry-run results in:
Processing /etc/letsencrypt/renewal/complete-concrete-concise.com.conf
http-01 challenge for faqbite.com
http-01 challenge for www.faqbite.com
http-01 challenge for complete-concrete-concise.com
http-01 challenge for www.complete-concrete-concise.com
Waiting for verification…
Attempting to renew cert (complete-concrete-concise.com) from /etc/letsencrypt/renewal/complete-concrete-concise.com.conf produced an unexpected error: Failed authorization procedure. www.complete-concrete-concise.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.complete-concrete-concise.com/.well-known/acme-challenge/Q9KlKi5_np590W-eBQozBw93v-W8rvKMqnotVrQYzOU: “\n\n404 Not Found\n<script src=”/cdn-cgi/apps/head/vDH", complete-concrete-concise.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://complete-concrete-concise.com/.well-known/acme-challenge /rp0A8itFOH9Wamakm8Z_kWXkb0gv9010VNjLBWQ4vG4: “\n\n404 Not Found\n<script src=”/cdn-cgi/apps/head/vDH". Skipping.
/etc/letsencrypt/live/complete-concrete-concise.com/fullchain.pem (failure)
Domain: www.complete-concrete-concise.com
Detail: Invalid response from
src=”/cdn-cgi/apps/head/vDH"Domain: complete-concrete-concise.com
http://complete-concrete-concise.com/.well-known/acme-challenge/rp0A8itFOH9Wamakm8Z_kWXkb0gv9010VNjLBWQ4vG4:
src=”/cdn-cgi/apps/head/vDH"To fix these errors, please make sure that your domain name was
My apache config file for the site is:
# The ServerName directive sets the request scheme, hostname and port that # the server uses to identify itself. This is used when creating # redirection URLs. In the context of virtual hosts, the ServerName # specifies what hostname must appear in the request's Host: header to # match this virtual host. For the default virtual host (this file) this # value is not decisive as it is used as a last resort host regardless. # However, you must set it for any further virtual host explicitly. #ServerName www.example.com ServerAdmin webmaster@localhost
ServerName complete-concrete-concise.com
ServerAlias www.complete-concrete-concise.com
DocumentRoot /var/www/complete-concrete-concise.com/public_html
#DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
RewriteEngine on
SSLCertificateFile /etc/letsencrypt/live/complete-concrete-concise.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/complete-concrete-concise.com/privkey.pem
