Problem with certificate creation
My domain is: www.kamieniarstwo-kamar.pl
I ran this command: sudo certbot --apache -d www.kamieniarstwo-kamar.pl
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
root@kamar:/opt/letsencrypt# apachectl -V
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 188.116.7.84. Set the 'ServerName' directive globally to suppress this message
Server version: Apache/2.4.10 (Debian)
Server built:   Mar 31 2018 09:39:03
Server's Module Magic Number: 20120211:37
Server loaded:  APR 1.5.1, APR-UTIL 1.5.4
Compiled using: APR 1.5.1, APR-UTIL 1.5.4
Architecture:   64-bit
Server MPM:     event
  threaded:     yes (fixed thread count)
    forked:     yes (variable process count)
Server compiled with....
 -D APR_HAS_SENDFILE
 -D APR_HAS_MMAP
 -D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
 -D APR_USE_SYSVSEM_SERIALIZE
 -D APR_USE_PTHREAD_SERIALIZE
 -D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
 -D APR_HAS_OTHER_CHILD
 -D AP_HAVE_RELIABLE_PIPED_LOGS
 -D DYNAMIC_MODULE_LIMIT=256
 -D HTTPD_ROOT="/etc/apache2"
 -D SUEXEC_BIN="/usr/lib/apache2/suexec"
 -D DEFAULT_PIDLOG="/var/run/apache2.pid"
 -D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
 -D DEFAULT_ERRORLOG="logs/error_log"
 -D AP_TYPES_CONFIG_FILE="mime.types"
 -D SERVER_CONFIG_FILE="apache2.conf"
Linux kamar 2.6.32-042stab125.3 #1 SMP Wed Sep 27 19:27:11 MSK 2017 x86_64 GNU/Linux
Debian 8.0 x86_64 minimal
My hosting provider, if applicable, is: hitme.pl
Please see
