My domain is: biobankportalen.se/mymmetingdocs.com
I ran this command: certbot --nginx
Failed authorization procedure. biobankportalen.se (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://biobankportalen.se/.well-known/acme-challenge/5kngHJOsBPBPupsyIeIp-WEsToquDtqdU33666gJFBA: Error getting validation data
nginx/1.10.3 (Ubuntu)
Ubuntu 16.04 LTS
no
I think my problem is that I copied my config for a working site in the same nginx-config and also copie the 301 redirect from http->https so that the certbot request is now redirected to https before ever having had a valid cert…
I’m quite new to this so it might be that I’m totally wrong.
To make matters a bit worse, I do run multiple servers/domains on the same machine (same nginx).
Any help is greatly appreciated, please let me know if I should post any other output. Unfortunately I just ran in to “There were too many requests of a given type :: Error creating new authz :: too many failed authorizations recently”, which is why I haven’t included any more output allready.
