but all I get is this error for each domain (www and non-www):
Domain: mysite.net
Type: connection
Detail: Could not connect to http://domain.com/.well-known/acme-challenge/53K6nhTF2Cn-yYaDv7seAsKSG5yOP0aLMG9-uHXOIuo
The DNS is configured correctly and my Apache should handle hidden directories (./foobar) as well. So, before I change s.th.: Might this error occur because of this permanent redirection to non-www https or is there another problem?
So, it’s not possible to use --webroot on HTTPS-only sites? And what should I do now? can I use the standalone-command to get one cert for every domain?
Your site isn’t HTTPS-only. In that ticket, there’s no server listening on port 80. Yours is. It’s just redirecting to HTTPS, which is another scenario and should be supported.
Okay, then maybe Apache isn’t allowed to serve hidden directories/files. Will try to troubleshoot this. If you know, how I easily can check this, I would appriciate this.
“Could not connect to” suggests Boulder can’t connect to the IP on port 80 entirely… Make 100% sure your server is connectable from the outside world.
If you’d post (or private message) the hostname(s) of the server, it’s easier to debug the problem.
It definitely is. Just pinged it and visited with diffrerent browsers to prevent cache-issues. If I visit http://www.domain.com it redirects me to https://domain.com. Tried it with every domain, but as it’s the same server/IP it works of course, too.
Okay, it seems there is s.th. wrong with my rewrite-engine-code. I created a hidden folder and copied a picture into it (http://www.domain.com/.test/picture.png). If I try to visit the picture with my browser it redirects me to https://domain.com.test/picture.png. Here are my .conf files for Apache2:
But I’ve no idea how to fix it, because I’m a total noob on this rewrite-thing. I asked others for this special stuff. It’s like chinese to me and I live far away from China.
I can see one very clear difference between both URL's in your post above. I can also read very clear many parts about the thingy that is different between the two URL's in the documentation I provided earlier..
No, I'm not going to tell you exactly what it is, you should be able to find out yourself
OK OK, fair enough, the problem isn't really literally mentioned in the documentation. Another tip: the thingy you "search" for in your Redirect (first argument) should match every "thingy" in the second argument (i.e.: destination) and that's not matching in your configuration right now.
The directive takes the whole path from the original request, strips the first argument of the Redirect directive and replaces that argument with whatever you’ve put behind it. By not adding the slash to your second argument, you’re replacing the single slash with a value without it.
Congratulations! Your certificate and chain have been saved at /etc/letsencrypt/live/domain.com/fullchain.pem
Am I right, that this way I can use the certificate for as many domains as I want? I only have to add the domains and fire up the command (see below) again?
But if you’re still in your testing phase, you should watch out for the rate limits. When testing, use the --staging option. This will do all the normal stuff, but generate a non-trusted certificate. Once everything is in order, you should only once remove the --staging switch for the real deal.
