Till now:
root@vserv2200.swisslink.ch:/root# certbot certificates -d kreator.ch
No certs found.
Till now:
No certs found.
Yes, that is expected.
Try:
./certbot certonly -d kreator.ch --apache
root@vserv2200.swisslink.ch:/root# certbot certonly -d kreator.ch --apache
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
OK the previous certs are gone.
The only way to get a cert now is with a system that has a certā¦
STOP APACHE
And try:
./certbot certonly -d kreator.ch -d www.kreator.ch --standalone
Here the log:
2019-02-01 04:26:33,133:DEBUG:certbot.main:Root logging level set at 20
2019-02-01 04:26:33,133:INFO:certbot.main:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2019-02-01 04:26:33,134:DEBUG:certbot.main:certbot version: 0.10.2
2019-02-01 04:26:33,134:DEBUG:certbot.main:Arguments: ['-d', 'kreator.ch', '--apache']
2019-02-01 04:26:33,134:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint$
2019-02-01 04:26:33,135:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
2019-02-01 04:26:33,955:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin - Beta
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.configurator:ApacheConfigurator
Initialized: <certbot_apache.configurator.ApacheConfigurator object at 0x7fef2e53b150>
Prep: True
2019-02-01 04:26:33,958:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Prep: True
2019-02-01 04:26:33,959:DEBUG:certbot.plugins.selection:Selected authenticator <certbot_apache.configurator.ApacheConfi$
2019-02-01 04:26:33,991:DEBUG:certbot.main:Picked account: <Account(3977b6509a888cf23c46922dfe620be0)>
2019-02-01 04:26:33,992:DEBUG:root:Sending GET request to https://acme-v01.api.letsencrypt.org/directory.
2019-02-01 04:26:33,995:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v01.api.l$
2019-02-01 04:26:34,312:DEBUG:requests.packages.urllib3.connectionpool:"GET /directory HTTP/1.1" 200 658
2019-02-01 04:26:34,313:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 658
Replay-Nonce: f0eonkea8ZlHrudoCHRkBIrifPSwl-KDmFLkwxlNAWY
X-Frame-Options: DENY
Expires: Fri, 01 Feb 2019 04:26:34 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Fri, 01 Feb 2019 04:26:34 GMT
"UHwoOvtRh1o": "Adding random entries to the directory",
"key-change": "https://acme-v01.api.letsencrypt.org/acme/key-change",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"terms-of-service": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"new-authz": "https://acme-v01.api.letsencrypt.org/acme/new-authz",
"new-cert": "https://acme-v01.api.letsencrypt.org/acme/new-cert",
"new-reg": "https://acme-v01.api.letsencrypt.org/acme/new-reg",
"revoke-cert": "https://acme-v01.api.letsencrypt.org/acme/revoke-cert"
2019-02-01 04:26:34,313:INFO:certbot.main:Obtaining a new certificate
2019-02-01 04:26:34,314:DEBUG:root:Requesting fresh nonce
2019-02-01 04:26:34,314:DEBUG:root:Sending HEAD request to https://acme-v01.api.letsencrypt.org/acme/new-authz.
Bingo.![]()
live folder created
Please show:
ls -lR /etc/letsencrypt/live/
Try restarting Apache.
I had to adapt ssl.conf
Apache restarted
āOnlyā this: not yet
Iāll reboot the server
yes to new path for new cert
We are getting close to the (old) target
Yes and from there I think we can move forward with certbot-auto
You wonāt have to remove certbot (for now it still serving a good purpose)
This would be to nice,
1: kreator.ch
2: mathias.kreator.ch
3: www.kreator.ch
blank to select all options shown (Enter ācā to cancel): 1
http-01 challenge for kreator.ch
Error while running apache2ctl graceful.
httpd not running, trying to start
Action āgracefulā failed.
From apache error log:
[Fri Feb 01 02:19:19.077320 2019] [ssl:emerg] [pid 1561:tid 139812496062336] AH02572: Failed to configure at least one
[Fri Feb 01 02:19:19.077355 2019] [ssl:emerg] [pid 1561:tid 139812496062336] SSL Library Error: error:140A80B1:SSL rout
[Fri Feb 01 02:19:19.077366 2019] [ssl:emerg] [pid 1561:tid 139812496062336] AH02311: Fatal error initialising mod_ssl,
AH00016: Configuration Failed
[Fri Feb 01 02:57:20.461720 2019] [ssl:emerg] [pid 3811:tid 139626587768704] AH02572: Failed to configure at least one
[Fri Feb 01 02:57:20.461767 2019] [ssl:emerg] [pid 3811:tid 139626587768704] SSL Library Error: error:140A80B1:SSL rout$
[Fri Feb 01 02:57:20.461778 2019] [ssl:emerg] [pid 3811:tid 139626587768704] AH02311: Fatal error initialising mod_ssl,$
We already have a working method to get those certs.
In fact you can get them all in one cert with:
stop apache
certbot certonly -d kreator.ch -d www.kreator.ch -d mathias.kreator.ch --standalone
or separately with:
stop apache
certbot certonly -d kreator.ch --standalone
certbot certonly -d www.kreator.ch --standalone
certbot certonly -d mathias.kreator.ch --standalone
or any combination you desire.
But that is using TLS-SNI-01 and stopping/restarting a web server to get cert(s) [far from ideal].
Please show this state now:
./certbot-auto certificates
Reached the limit with the first one:
root@vserv2200.swisslink.ch:/root# service apache2 stop
root@vserv2200.swisslink.ch:/root# certbot certonly -d kreator.ch --standalone
Waiting for verificationā¦
Generating key (2048 bits): /etc/letsencrypt/keys/0010_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0010_csr-certbot.pem
An unexpected error occurred:
There were too many requests of a given type :: Error creating new cert :: too many certificates already issued for exact set of domains: kreator.ch: see https://letsencrypt.org/docs/rate-limits/
You already have a cert for that name - why run that command again?
Please show:
./certbot certificates
I thought it was your instruction
Found the following certs:
Certificate Name: kreator.ch
Domains: kreator.ch www.kreator.ch
Expiry Date: 2019-05-02 03:35:09+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/kreator.ch/fullchain.pem
Private Key Path: /etc/letsencrypt/live/kreator.ch/privkey.pem
If you want my opinion/instruction...
Get one cert (to cover all three names - simplifies things, for now):
