Problem updating ACME TLS-SNI-01 to alternative validation method
Unable to clean up challenge directory /var/www/kreator.ch/.well-known/acme-challenge
That probably just means the folder isn’t empty - not a real concern
Did it say ā€œCongratulations!..ā€ ?
Unfortunately: non.
Seems to be a mix between certbot & certbot-auto.
Maybe I should uninstall the latter.
In the past I did not have these .Well-known/acme … (seems to me)
The answer was:
Domain: kreator.ch
Type: connection
Detail: Fetching
http://kreator.ch/.well-known/acme-challenge/m6rgLXlLQxR_iC8Nfa-vTJptEwKKd_X-bhW3u2wJgS4:
Connection refused
Rem: I do not have fire-wall
certbot-auto is a ā€œself-containedā€ system.
It should not be causing a grief.
Well that is the same http problem we have been trying to overcome.
You need to do the opposite here then.
And force https authentication:
./certbot [whatever you had +] --preferred_challenges https
Do you have TeanViewer ?
I could give you access to my server this way. It would go faster …
My ā€œTVā€ PC(laptop) is down at the moment…
The fan won’t spin so it refuses to boot [better safe than sorry I suppose].
So, no I can’t - sorry.
Lol.
root@vserv2200.swisslink.ch:/root# certbot renew --preferred-challenges https
An unexpected error occurred:
ArgumentTypeError: Unrecognized challenges: https
Please see the logfile 'certbot.log' for more details.
OMG!!!
cerbot --version
BRAIN FAAART!
It’s NOT HTTPS
use
TLS-SNI-01
certbot renew --preferred-challenges tls-sni-01
Certbot seems to be dead !!!
cerbot --version
-su: cerbot: command not found
cerTbot --version
[all lowercase]
It was all lowercase
c e r b o t
c e r t b o t
yours was missing the middle T
Sorry
certbot 0.10.2
but try this :slight_smile:
No renewals were attempted.
Its’ very late…
Its’ very early…
Its’ both.
Ok a step in the right direction.
certbot certificates
is empty, so it can't RENEW anything.
So you need to get new with "certonly" and without "renew"
And if it doesn't prompt you for domain(s), we'll have to add them with "-d"
[and possibly "--apache" also - or "--webroot"]
