Problem to renew the certificate
My domain is: vllobet.cat
I ran this command: certbot-auto renew
Processing /etc/letsencrypt/renewal/vllobet.cat.conf
http-01 challenge for vllobet.cat
http-01 challenge for www.vllobet.cat
Waiting for verification…
Attempting to renew cert (vllobet.cat) from /etc/letsencrypt/renewal/vllobet.cat.conf produced an unexpected error: Failed authorization procedure. vllobet.cat (http-01): urn:acme:error:unknownHost :: The server could not resolve a domain name :: No valid IP addresses found for vllobet.cat. Skipping.
/etc/letsencrypt/live/vllobet.cat/fullchain.pem (failure)
    Domain: vllobet.cat
    Type: unknownHost
    Detail: No valid IP addresses found for vllobet.cat
My web server is (include version): debian 8.10 jessie
My hosting provider, if applicable, is: hostwinds
Good afternoon.
I’m very new to this and that’s why I ask for help through the forum. I imagine that the problem that I will pose is more than reported; but I do not get along well with English and do what I can … apologize for it.
At the time I got the courage to create a certificate and install it on the server where I have a Wordpress deployed. Well, until there and except for a couple of questions, I managed to deploy the server certificate.
Today I have to renew the certificate, since it expires on June 8 and the system returns errors that I do not know where to fix them.
The wordpress installation path is: /var/www/html/wordpress
The letsencrypt path is: /etc/bin/letsencrypt
Please help!!
I created a hello.txt inside /var/www/html/wordpress/.well-know and this is visible from the browser.
I do not know where else to look.
:frowning:
www.vllobet.cat has an IP address:
$ host www.vllobet.cat
www.vllobet.cat has address 104.168.156.253
But vllobet.cat doesn’t.
You have to go to your DNS control panel and add an A record with that IP (probably).
Oh yeah!!
Fantastic!! That was the problem.
It has been adding the host “@” pointing to IP 104.168.156.253 and the certificate has already been renewed.
Thank you very much for the help and for the speed.
Now what I have left is to program it in the Linux cron.
regards
