Problem renewing wildcard subdomain witn dns-cloudflare authenticator
Good day,
my certificate is a wildcard certificate for my domain and a subdomain in my domain. It appears that the DNS update for the base domain works, but that of the subdomain fails. I've changed the api token resources to "All Domains" in Cloudflare but I still get "Domain: neptune.4gl.dev unauthorized" when I do a dry-run.
The domains in the certificate is: *.4gl.dev and *.neptune.4gl.dev
sudo certbot renew -v --dry-run --dns-cloudflare --dns-cloudflare-credentials /etc/certbot/.cloudflare
Processing /etc/letsencrypt/renewal/4gl.dev.conf
Certificate not due for renewal, but simulating renewal for dry run
Plugins selected: Authenticator dns-cloudflare, Installer None
Simulating renewal of an existing certificate for *.4gl.dev and *.neptune.4gl.dev
dns-01 challenge for 4gl.dev
dns-01 challenge for neptune.4gl.dev
Waiting 10 seconds for DNS changes to propagate
Challenge failed for domain neptune.4gl.dev
Certbot failed to authenticate some domains (authenticator: dns-cloudflare). The Certificate Authority reported these problems:
Detail: Incorrect TXT record "emxReSvF2dbJHUBg_5P7bfZcacxabQ07Qs6jt4QNrJY" found at _acme-challenge.neptune.4gl.dev
Hint: The Certificate Authority failed to verify the DNS TXT records created by --dns-cloudflare. Ensure the above domains are hosted by this DNS provider, or try increasing --dns-cloudflare-propagation-seconds (currently 10 seconds).
Failed to renew certificate 4gl.dev with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/4gl.dev/fullchain.pem (failure)
Ubuntu 22.04.5 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 3.2.0
Looking at /etc/letsencrypt/renewal/4gl.dev.conf I see the following, what I do not understand is why it says that the authenticator is manual:
renew_before_expiry = 30 days
version = 3.0.1
archive_dir = /etc/letsencrypt/archive/4gl.dev
cert = /etc/letsencrypt/live/4gl.dev/cert.pem
privkey = /etc/letsencrypt/live/4gl.dev/privkey.pem
chain = /etc/letsencrypt/live/4gl.dev/chain.pem
fullchain = /etc/letsencrypt/live/4gl.dev/fullchain.pem
[renewalparams]
account = 8c23a81085478ee3e83229b456ff9f84
pref_challs = dns-01,
authenticator = manual
key_type = ecdsa
I'd allow at least 30 seconds for DNS changes to replicate amongst your nameservers, 10 seconds seems a bit quick.
Interesting. It appears that _acme-challenge.neptune.4gl.dev was never updated. It still existed since the last time I manually renewed the certificate.
I proceeded to delete both _acme-challenge.4gl.dev and _acme-challenge.neptune.4gl.dev and tried again. This time it worked. The challenges were also both removed automatically after the validation succeeded.
Looks like certbot does not like it if there are old ones on the DNS server.
Indeed. Ten seconds are not enough. After doing the cleanup in my other post, I had to increase it to 30 like you suggested to get proper results.
Certbot doesn't check nor cares.
