Hello.
I'm having trouble obtaining my certificate.
There's something unusual about it.
Can you help me figure it out?
We've received your email and assigned it ticket ID 18018.
To add additional comments, reply to this email.
[root@localhost ~]# ss -tunlp
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
udp UNCONN 0 0 0.0.0.0:4789 0.0.0.0:*
udp UNCONN 0 0 192.168.1.4:7946 0.0.0.0:* users:(("dockerd",pid=1190,fd=26))
udp UNCONN 0 0 127.0.0.1:323 0.0.0.0:* users:(("chronyd",pid=957,fd=4))
udp UNCONN 0 0 [::1]:323 [::]:* users:(("chronyd",pid=957,fd=5))
udp UNCONN 0 0 [fe80::12c3:7bff:fe93:44a4]%eno1:546 [::]:* users:(("NetworkManager",pid=1030,fd=27))
tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:* users:(("sshd",pid=1078,fd=7))
tcp LISTEN 0 100 127.0.0.1:25 0.0.0.0:* users:(("master",pid=1171,fd=13))
tcp LISTEN 0 2048 192.168.1.4:7946 0.0.0.0:* users:(("dockerd",pid=1190,fd=25))
tcp LISTEN 0 2048 192.168.1.4:2377 0.0.0.0:* users:(("dockerd",pid=1190,fd=22))
tcp LISTEN 0 128 [::]:22 [::]:* users:(("sshd",pid=1078,fd=8))
tcp LISTEN 0 100 [::1]:25 [::]:* users:(("master",pid=1171,fd=14))
[root@localhost ~]# certbot certonly --standalone -d globalmarket.center
Requesting a certificate for globalmarket.center
Identifier: globalmarket.center
Type: connection
Detail: 80.240.248.42: Fetching http://globalmarket.center/.well-known/acme-challenge/5bA3iNdseBYY01vj3y9LyhAxibnLcv1iULJlBu5Jk5g: Error getting validation data
[root@localhost ~]# cat /var/log/letsencrypt/letsencrypt.log
2026-04-09 12:30:30,392:DEBUG:urllib3.connectionpool:http://localhost:None "GET /v2/connections?snap=certbot&interface=content HTTP/1.1" 200 97
2026-04-09 12:30:31,373:DEBUG:certbot._internal.main:certbot version: 5.5.0
2026-04-09 12:30:31,374:DEBUG:certbot._internal.main:Location of certbot entry point: /snap/certbot/5528/bin/certbot
2026-04-09 12:30:31,374:DEBUG:certbot._internal.main:Arguments: ['--standalone', '-d', 'globalmarket.center', '--preconfigured-renewal']
2026-04-09 12:30:31,374:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2026-04-09 12:30:31,431:DEBUG:certbot._internal.log:Root logging level set at 30
2026-04-09 12:30:31,436:DEBUG:certbot._internal.plugins.selection:Requested authenticator standalone and installer None
2026-04-09 12:30:31,436:DEBUG:certbot._internal.plugins.selection:Single candidate plugin: * standalone
Description: Runs an HTTP server locally which serves the necessary validation files under the /.well-known/acme-challenge/ request path. Suitable if there is no HTTP server already running. HTTP challenge only (wildcards not supported).
Interfaces: Authenticator, Plugin
Entry point: EntryPoint(name='standalone', value='certbot._internal.plugins.standalone:Authenticator', group='certbot.plugins')
Initialized: <certbot._internal.plugins.standalone.Authenticator object at 0x7fcbc7619cd0>
Prep: True
2026-04-09 12:30:31,437:DEBUG:certbot._internal.plugins.selection:Selected authenticator <certbot._internal.plugins.standalone.Authenticator object at 0x7fcbc7619cd0> and installer None
2026-04-09 12:30:31,437:INFO:certbot._internal.plugins.selection:Plugins selected: Authenticator standalone, Installer None
2026-04-09 12:30:31,491:DEBUG:certbot._internal.main:Picked account: <Account(RegistrationResource(body=Registration(key=None, contact=(), agreement=None, status=None, terms_of_service_agreed=None, only_return_existing=None, external_account_binding=None), uri='https://acme-v02.api.letsencrypt.org/acme/acct/3168244031', new_authzr_uri=None, terms_of_service=None), a6c90c6768a97ddea1519ec11f70bae5, Meta(creation_dt=datetime.datetime(2026, 3, 22, 9, 0, 18, tzinfo=datetime.timezone.utc), creation_host='Unknown', register_to_eff='a.lezhepekov@yandex.ru'))>
2026-04-09 12:30:31,492:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2026-04-09 12:30:31,493:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org:443
2026-04-09 12:30:32,352:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "GET /directory HTTP/1.1" 200 1033
2026-04-09 12:30:32,352:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 09 Apr 2026 09:30:32 GMT
Content-Length: 1033
X-Frame-Options: DENY
"meta": {
"caaIdentities": [
"letsencrypt.org"
"profiles": {
"classic": "https://letsencrypt.org/docs/profiles#classic",
"shortlived": "https://letsencrypt.org/docs/profiles#shortlived",
"tlsclient": "https://letsencrypt.org/docs/profiles#tlsclient",
"tlsserver": "https://letsencrypt.org/docs/profiles#tlsserver"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.6-August-18-2025.pdf",
"renewalInfo": "https://acme-v02.api.letsencrypt.org/acme/renewal-info",
"revokeCert": "https://acme-v02.api.letsencrypt.org/acme/revoke-cert",
"zYMaEnQ8fU4": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417"
2026-04-09 12:30:32,352:DEBUG:certbot._internal.display.obj:Notifying user: Requesting a certificate for globalmarket.center
2026-04-09 12:30:32,354:DEBUG:acme.client:Requesting fresh nonce
2026-04-09 12:30:32,354:DEBUG:acme.client:Sending HEAD request to https://acme-v02.api.letsencrypt.org/acme/new-nonce.
2026-04-09 12:30:32,593:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "HEAD /acme/new-nonce HTTP/1.1" 200 0
2026-04-09 12:30:32,593:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Replay-Nonce: v9ARF6dgEMPzuO-HEXamoKzm3xI8gL3NqAjnxVeYOS84dD0x-Vc
2026-04-09 12:30:32,593:DEBUG:acme.client:Storing nonce: v9ARF6dgEMPzuO-HEXamoKzm3xI8gL3NqAjnxVeYOS84dD0x-Vc
2026-04-09 12:30:32,594:DEBUG:acme.client:JWS payload:
b'{\n "identifiers": [\n {\n "type": "dns",\n "value": "globalmarket.center"\n }\n ]\n}'
2026-04-09 12:30:32,595:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/new-order:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzE2ODI0NDAzMSIsICJub25jZSI6ICJ2OUFSRjZkZ0VNUHp1Ty1IRVhhbW9Lem0zeEk4Z0wzTnFBam54VmVZT1M4NGREMHgtVmMiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL25ldy1vcmRlciJ9",
"signature": "Er_BCVRl8i_m6F7mGZrD_mqUVyWMZEQHUXANhfdTBPzVldXzz8CrcG_5rMAgGpR31KeA5xCGuF4NnFEEhZy3j6N_VlZ8fxH6dntGJyNoH29SeNAKteMuNnPqZjZRnhJs-bcaqdHQ5nGxUB1D0GPQe3HC-48KSECowywyGV6UQ3t_lxwMthV9su3EwLUnJ287x-pTshnZBQOx2wdmMXNTDnJOQzsKhSu8pMzP50Uhmr1H_tL4_Lic9sGOTBi4S1X6DUt-J6DbiW4WjPbsXGWRUp2sej8_az3n943Xmi7qOrRl33OyP0W46GdAtatp2AqxlF5hAJNLMyTCeTsanrf70Q",
"payload": "ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwKICAgICAgInZhbHVlIjogImdsb2JhbG1hcmtldC5jZW50ZXIiCiAgICB9CiAgXQp9"
2026-04-09 12:30:32,993:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/new-order HTTP/1.1" 201 353
2026-04-09 12:30:32,994:DEBUG:acme.client:Received response:
HTTP 201
Server: nginx
Content-Length: 353
Boulder-Requester: 3168244031
Location: https://acme-v02.api.letsencrypt.org/acme/order/3168244031/498881097311
Replay-Nonce: v9ARF6dgkwATU9J4iaIbN7IZBv_Y--LGIEwoyUi6Hmnbol9McTc
"status": "pending",
"expires": "2026-04-16T09:30:32Z",
"identifiers": [
"type": "dns",
"authorizations": [
"https://acme-v02.api.letsencrypt.org/acme/authz/3168244031/685492587581"
"finalize": "https://acme-v02.api.letsencrypt.org/acme/finalize/3168244031/498881097311"
2026-04-09 12:30:32,994:DEBUG:acme.client:Storing nonce: v9ARF6dgkwATU9J4iaIbN7IZBv_Y--LGIEwoyUi6Hmnbol9McTc
2026-04-09 12:30:32,994:DEBUG:acme.client:JWS payload:
b''
2026-04-09 12:30:32,995:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz/3168244031/685492587581:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzE2ODI0NDAzMSIsICJub25jZSI6ICJ2OUFSRjZkZ2t3QVRVOUo0aWFJYk43SVpCdl9ZLS1MR0lFd295VWk2SG1uYm9sOU1jVGMiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LzMxNjgyNDQwMzEvNjg1NDkyNTg3NTgxIn0",
"signature": "AhebND28jh-wYw6rbQhC7Kmp-ImC1lUQMMwFAUlrkDEth-dU-r5LgziELi8yOWFYQUBik9NaKwKZrgNYfoiteuai-gIDrEMHm0G0LCcTdVsusSZ0p0gGD_5QobI8F6ZSqbK1gDyM9EQ_DOWSnN_EW2iWqmUFWO6lKob9xslcMe-33Y8vWRUAMXKGkKp5HpOXl4XhxCQboqu60QRVkNr5YAaeVFCXwg15PpKLso4Gc7gRQZwDvZmPpNzeDJd3cY1vOOx58uh9qWk_VxQiPIszYljKjQdYVlFREKk-GjnEmjrPrL0N1LaH3PdJ2Swr63I3qnqqT3x4FKnVdLVgWLlxQA",
"payload": ""
2026-04-09 12:30:33,237:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz/3168244031/685492587581 HTTP/1.1" 200 827
2026-04-09 12:30:33,237:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 09 Apr 2026 09:30:33 GMT
Content-Length: 827
Replay-Nonce: v9ARF6dgNGxjD9uXBeRT_grYEpw4HoaiPzKJFLB2c0ssZWj15jA
"identifier": {
"type": "dns",
"challenges": [
"type": "tls-alpn-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/3168244031/685492587581/OAmg3A",
"token": "5bA3iNdseBYY01vj3y9LyhAxibnLcv1iULJlBu5Jk5g"
"type": "dns-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/3168244031/685492587581/p5ibFg",
"type": "http-01",
"url": "https://acme-v02.api.letsencrypt.org/acme/chall/3168244031/685492587581/S818vg",
2026-04-09 12:30:33,237:DEBUG:acme.client:Storing nonce: v9ARF6dgNGxjD9uXBeRT_grYEpw4HoaiPzKJFLB2c0ssZWj15jA
2026-04-09 12:30:33,237:DEBUG:acme.challenges:tls-alpn-01 was not recognized, full message: {'type': 'tls-alpn-01', 'url': 'https://acme-v02.api.letsencrypt.org/acme/chall/3168244031/685492587581/OAmg3A', 'status': 'pending', 'token': '5bA3iNdseBYY01vj3y9LyhAxibnLcv1iULJlBu5Jk5g'}
2026-04-09 12:30:33,237:INFO:certbot._internal.auth_handler:Performing the following challenges:
2026-04-09 12:30:33,237:INFO:certbot._internal.auth_handler:http-01 challenge for Identifier(typ=IdentifierType(dns), value='globalmarket.center')
2026-04-09 12:30:33,238:DEBUG:acme.standalone:Successfully bound to :80 using IPv6
2026-04-09 12:30:33,239:DEBUG:acme.standalone:Certbot wasn't able to bind to :80 using IPv4, this is often expected due to the dual stack nature of IPv6 socket implementations.
2026-04-09 12:30:33,240:DEBUG:acme.client:JWS payload:
b'{}'
2026-04-09 12:30:33,240:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/chall/3168244031/685492587581/S818vg:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzE2ODI0NDAzMSIsICJub25jZSI6ICJ2OUFSRjZkZ05HeGpEOXVYQmVSVF9ncllFcHc0SG9haVB6S0pGTEIyYzBzc1pXajE1akEiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2NoYWxsLzMxNjgyNDQwMzEvNjg1NDkyNTg3NTgxL1M4MTh2ZyJ9",
"signature": "iMXg5I6DfaJHKnWrYRnwRdLTXrIrFJ6YbtYKFltQ4tLfkoTgXJ36OEWTekxXjX708N4oVFQZh9yFLnj9OOFjKnfd4813I3EMe5I3SuDMcZPD9s2d-4TPdRtczUGgYfIJDv6pvqVH8zC2bmfJRuUHPgPXYGlxuBCn_hOlSuSJY4T5NhiPNlFIPp2drdA90w7n7ou8ppPViavtAHEfjJJZEkt1fG62NJVXIXmXI-oCQgkiI7Q2EjrneMaYtrOb23j-KZlqE5wuNMkdM3cfweEK5IqLpsCwo4H7P2otsA-ioF4KJZgr-UfKXZIVlYsaIKIZawK9oyq7yJvqni_DNkcukg",
"payload": "e30"
2026-04-09 12:30:33,497:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/chall/3168244031/685492587581/S818vg HTTP/1.1" 200 195
2026-04-09 12:30:33,497:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 195
Link: <https://acme-v02.api.letsencrypt.org/directory>;rel="index", <https://acme-v02.api.letsencrypt.org/acme/authz/3168244031/685492587581>;rel="up"
Location: https://acme-v02.api.letsencrypt.org/acme/chall/3168244031/685492587581/S818vg
Replay-Nonce: e8SfZ44tJAdnASgAPspL2JNTvZHnSpsQAoyowf4wpHZu9qzIef0
"type": "http-01",
2026-04-09 12:30:33,497:DEBUG:acme.client:Storing nonce: e8SfZ44tJAdnASgAPspL2JNTvZHnSpsQAoyowf4wpHZu9qzIef0
2026-04-09 12:30:33,498:INFO:certbot._internal.auth_handler:Waiting for verification...
2026-04-09 12:30:34,498:DEBUG:acme.client:JWS payload:
b''
2026-04-09 12:30:34,499:DEBUG:acme.client:Sending POST request to https://acme-v02.api.letsencrypt.org/acme/authz/3168244031/685492587581:
"protected": "eyJhbGciOiAiUlMyNTYiLCAia2lkIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2FjY3QvMzE2ODI0NDAzMSIsICJub25jZSI6ICJlOFNmWjQ0dEpBZG5BU2dBUHNwTDJKTlR2WkhuU3BzUUFveW93ZjR3cEhadTlxekllZjAiLCAidXJsIjogImh0dHBzOi8vYWNtZS12MDIuYXBpLmxldHNlbmNyeXB0Lm9yZy9hY21lL2F1dGh6LzMxNjgyNDQwMzEvNjg1NDkyNTg3NTgxIn0",
"signature": "hC4r1ckPIgSr-U6n4bFt77nOJn86qtLNtB6_F3vglwQIxPTuTB747hhnmdVYONBQzQukxwvPhFeU7fKEvzR5PKIBcjs_f2n9F_cuqlNByz1dGDO9bMpPvy7c5WEBYtbEkP_XFWHjZ7JkR3MX2pJXu1fRJzFZR0S2LUaaKH0TLVAOnXiib9noPk7Vr_VdQ835PKlaFZCOMW3Z08K3A45Ov-qgQBRJE2hoohtGFF44NTL8YJo624q4z_EVhdZeKZNBlnOUnzcf171MzSI97m98vAcKhM0Qa7xMnBeZ3RxzgZXWM1yeSbbjCy-vESG55rLmygcqrzhXLI0X1N2zdYv9pg",
"payload": ""
2026-04-09 12:30:34,743:DEBUG:urllib3.connectionpool:https://acme-v02.api.letsencrypt.org:443 "POST /acme/authz/3168244031/685492587581 HTTP/1.1" 200 1063
2026-04-09 12:30:34,744:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Date: Thu, 09 Apr 2026 09:30:34 GMT
Content-Length: 1063
Replay-Nonce: e8SfZ44tZ693DKGCic6z0xtOnENpJBTKgrZmyVHQt_jRdnV3wtM
"identifier": {
"type": "dns",
"status": "invalid",
"challenges": [
"type": "http-01",
"validated": "2026-04-09T09:30:33Z",
"error": {
"type": "urn:ietf:params:acme:error:connection",
"detail": "80.240.248.42: Fetching http://globalmarket.center/.well-known/acme-challenge/5bA3iNdseBYY01vj3y9LyhAxibnLcv1iULJlBu5Jk5g: Error getting validation data",
"status": 400
"token": "5bA3iNdseBYY01vj3y9LyhAxibnLcv1iULJlBu5Jk5g",
"validationRecord": [
"url": "http://globalmarket.center/.well-known/acme-challenge/5bA3iNdseBYY01vj3y9LyhAxibnLcv1iULJlBu5Jk5g",
"hostname": "globalmarket.center",
"port": "80",
"addressesResolved": [
"80.240.248.42"
"addressUsed": "80.240.248.42"
2026-04-09 12:30:34,744:DEBUG:acme.client:Storing nonce: e8SfZ44tZ693DKGCic6z0xtOnENpJBTKgrZmyVHQt_jRdnV3wtM
2026-04-09 12:30:34,744:INFO:certbot._internal.auth_handler:Challenge failed for domain globalmarket.center
2026-04-09 12:30:34,744:INFO:certbot._internal.auth_handler:http-01 challenge for Identifier(typ=IdentifierType(dns), value='globalmarket.center')
2026-04-09 12:30:34,744:DEBUG:certbot._internal.display.obj:Notifying user:
Type: connection
2026-04-09 12:30:34,746:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/auth_handler.py", line 104, in handle_authorizations
self._poll_authorizations(authzrs, max_retries, max_time_mins, best_effort)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/auth_handler.py", line 208, in _poll_authorizations
2026-04-09 12:30:34,746:DEBUG:certbot._internal.error_handler:Calling registered functions
2026-04-09 12:30:34,746:INFO:certbot._internal.auth_handler:Cleaning up challenges
2026-04-09 12:30:34,746:DEBUG:certbot._internal.plugins.standalone:Stopping server at :::80...
2026-04-09 12:30:35,241:DEBUG:certbot._internal.log:Exiting abnormally:
File "/snap/certbot/5528/bin/certbot", line 6, in <module>
sys.exit(main())
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/main.py", line 18, in main
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/main.py", line 1886, in main
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/main.py", line 1598, in certonly
lineage = _get_and_save_cert(le_client, config, sans, certname, lineage)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
lineage = le_client.obtain_and_enroll_certificate(sans, certname)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/client.py", line 533, in obtain_and_enroll_certificate
cert, chain, key, _ = self.obtain_certificate(sans)
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/client.py", line 434, in obtain_certificate
File "/var/lib/snapd/snap/certbot/5528/lib/python3.12/site-packages/certbot/_internal/client.py", line 512, in _get_order_and_authorizations
2026-04-09 12:30:35,245:ERROR:certbot._internal.log:Some challenges have failed.
