Problem issuing SSL Certificate for ERPNext instance
Im using a subdomain
http://bsd-erp.phonevillemobile.com/
Server version: Apache/2.4.58 (Ubuntu)
Server built: 2024-10-02T12:40:51
Ubuntu 24.04.2 LTS
Hostinger
Yes
Ubuntu server
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
Steps to reproduce issue
cd to erpnext frappe-bench
sudo certbot
Result:
Encountered exception during recovery: certbot.errors.MisconfigurationError: nginx restart failed:
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] bind() to [::]:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
How can I resolve this?
If your web server is Apache, why is nginx trying (and failing) to restart? What was the rest of the certbot command, or the other options you chose?
Okay sorry I forgot to add it's supposed to be:
sudo certbot --nginx
I followed this steps from tutorial:
So why did you run certbot --nginx if your web server is Apache, as you said in your first post?
Your use of the --nginx flag explains what you're seeing: you're already running a web server (presumably Apache, as you mentioned in the first post), so trying to start another web server (nginx) isn't going to work, as they can't both listen on the same ports.
I've setup nginx to issue the SSL
sudo systemctl status nginx
● nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; preset: enabled)
Active: active (running) since Tue 2025-03-25 01:38:00 UTC; 18min ago
Docs: man:nginx(8)
Process: 16353 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process o>
Process: 16354 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=>
Main PID: 16356 (nginx)
Tasks: 3 (limit: 9486)
Memory: 2.6M (peak: 4.6M)
CPU: 85ms
CGroup: /system.slice/nginx.service
β”œβ”€16356 "nginx: master process /usr/sbin/nginx -g daemon on; master_pro>
β”œβ”€16475 "nginx: worker process"
└─16476 "nginx: worker process"
Now I'm facing this error:
Domain: <>
Detail: <>: Invalid response from <>/.well-known/acme-challenge/mFuRUSR0Ak0hwAjc_JAybmEaNueYhgZqUtEno-bt7wQ: "\n\n\n <link rel="stylesheet" type="text/css" class="meteor-css" href="/36408fc8183fca0a5d551568692"
How is Traefik involved? Because HTTPS connections to your domain using port 443 use a default cert from Traefik
openssl s_client -connect bsd-erp.phonevillemobile.com:443
Certificate:
subject=CN = TRAEFIK DEFAULT CERT
issuer=CN = TRAEFIK DEFAULT CERT
notBefore=Mar 24 03:25:17 2025 GMT
notAfter=Mar 24 03:25:17 2026 GMT
We have another application, Rocket.Chat , running on ports 80 and 443 , using Traefik for SSL. However, I don’t want to use Traefik for ERPNext SSL Is there a way to configure Nginx separately to handle SSL for ERPNext ?
That' s a better question for ERPNext support: Introduction
For at least the cert part, you may need to use a DNS Challenge rather than the HTTP Challenge you have been trying. Or, reconfigure Traefik to act as reverse-proxy for ERPNext.
Alright thanks.
