I have a domain say www.example.com that has a SSL certificate i purchased at a vendor
I have already installed a letsencrypt certificate for another domain on the same server say www.example2.com with no problem
./certbot-auto certonly --apache -d www.example2.com
i wanted to install another certificate not using the expand, so i will have another letsencrypt SSL certificate, then i get this error message
Domain: www.example2.com
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
edfdbe1da016a6dd095d0598023ef117.507ffcc61b07b09f1b9170ff48914223.acme.invalid
from 163.172.63.51:443. Received 2 certificate(s), first
certificate had names βexample.com, www.example.comβTo fix these errors, please make sure that your domain name was
all the vhost are on the same IP address. Why does certbot look into at www.example.com ? it has nothing to do with the domain I want to add.
thanks
