Problem creating certificate unauthorized
My domain is: guyschrift.com
I ran this command: sudo certbot certonly --standalone
It produced this output: Challenge failed for domain guyschrift.com
My web server is (include version): Apache Tomcat/9.0.29
The operating system my web server runs on is (include version): centos 7 on aws
My hosting provider, if applicable, is: aws
I can login to a root shell on my machine (yes or no, or I don’t know): no - but I use sudo
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.3.0
In order to run certbot in standalone mode you would first have to stop any other service on port 80.
Which is not really recommended.
But since you are running Apache Tomcat you just might have to.
[Tomcat is not easy to work with]
And also...
Your domain resolves to two IPs:
Addresses: 18.196.11.249
50.63.202.39
Do they both connect to the same system or to two separate systems?
