My domain is: pmway.hopto.org
I ran this command: I first ran certbot renew and I was given the error Problem binding port 80 win error 1013. I know that I can be locked out when this happens so I have started running certbot certonly --standalone --dry-run
Saving debug log to C:\Certbot\log\letsencrypt.log
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): pmway.hopto.org
Simulating a certificate request for pmway.hopto.org
Domain: pmway.hopto.org
Type: connection
Detail: 197.90.83.123: Fetching http://pmway.hopto.org/.well-known/acme-challenge/El-xOEyf8bWo3QKVuXTWeU18IAgDXZxwlSJEirL8_Bg: Timeout during connect (likely firewall problem)
Some challenges have failed. I noted that IIS was running. I have removed IIS and still the problem remains. I also used to easily run certbot renew but suddenly this is not working. AND I run this command: netstat -ano | find ":80" and I see that port 80 has 4 next to it as a PID. I wanted to run taskkill /PID 4 /f and I get this reply: ERROR: The process with PID 4 could not be terminated.
Reason: Access is denied. AND I have tried the above disabling the firewall as well. Same error. My certbot folder on the C:\ drive exists and I can see the certificates. AND the .well-known\acme-challenge\mytestfile.txt and certificate exist in the public folder of my web site.
My web server is (include version): A recent version of xampp for windows 10
The operating system my web server runs on is (include version): Up to date Windows 10
I can login to a root shell on my machine (yes or no, or I don't know): I serve the web site from my home server.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): xampp
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): I today put in the latest version of certbot.
