I'm renewing the certificate for my domain , every thing is fine but the private key with pem is only 241 bytes ,
the issue that I'm using this private key for ORDS installation and every time I getting the exception 2023-12-18T10:17:40.434Z SEVERE The provided key is not RSA or PKCS8 encoded
oracle.dbtools.standalone.StandaloneException: The provided key is not RSA or PKCS8 encoded
at oracle.dbtools.standalone.PEMCertificate$Builder.privateKey(PEMCertificate.java:482)
at oracle.dbtools.standalone.PEMCertificate.read(PEMCertificate.java:276)
at oracle.dbtools.standalone.StandaloneConfiguration.certificate(StandaloneConfiguration.java:370)
at oracle.dbtools.standalone.StandaloneConfiguration.start(StandaloneConfiguration.java:210)
at oracle.dbtools.standalone.Serve.start(Serve.java:148)
at oracle.dbtools.standalone.Serve.serve(Serve.java:125)
at oracle.dbtools.cmdline.CommandLineInterface$Instance$ExecutableCommand.execute(CommandLineInterface.java:1008)
at oracle.dbtools.standalone.Serve.execute(Serve.java:66)
at oracle.dbtools.cmdline.CommandLine$Dispatcher.execute(CommandLine.java:622)
at oracle.dbtools.cmdline.CommandLine.dispatch(CommandLine.java:141)
at oracle.dbtools.cmdline.CommandLineInterface$Instance.execute(CommandLineInterface.java:922)
at oracle.dbtools.cmdline.CommandLine.execute(CommandLine.java:100)
at oracle.dbtools.cmdline.CommandLine.execute(CommandLine.java:113)
at oracle.dbtools.cmdline.CommandLine.main(CommandLine.java:248)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at oracle.dbtools.launcher.executable.jar.ExecutableJarEntrypoint.invoke(ExecutableJarEntrypoint.java:54)
at oracle.dbtools.launcher.executable.jar.ExecutableJarEntrypoint.main(ExecutableJarEntrypoint.java:64)
Caused by: java.security.spec.InvalidKeySpecException: java.security.InvalidKeyException: IOException : DER input, Integer tag error
at java.base/sun.security.rsa.RSAKeyFactory.engineGeneratePrivate(RSAKeyFactory.java:251)
at java.base/java.security.KeyFactory.generatePrivate(KeyFactory.java:390)
at oracle.dbtools.standalone.PEMCertificate$Builder.privateKey(PEMCertificate.java:480)
... 20 more
Caused by: java.security.InvalidKeyException: IOException : DER input, Integer tag error
at java.base/sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:350)
at java.base/sun.security.pkcs.PKCS8Key.decode(PKCS8Key.java:355)
at java.base/sun.security.rsa.RSAPrivateCrtKeyImpl.(RSAPrivateCrtKeyImpl.java:130)
at java.base/sun.security.rsa.RSAPrivateCrtKeyImpl.newKey(RSAPrivateCrtKeyImpl.java:80)
at java.base/sun.security.rsa.RSAKeyFactory.generatePrivate(RSAKeyFactory.java:356)
at java.base/sun.security.rsa.RSAKeyFactory.engineGeneratePrivate(RSAKeyFactory.java:247)
... 22 more
I did some searches on Oracle ORDS topics and they are telling "Private key is corrupted"
any clue?
Thanks in advance
