Possible NGINX misconfiguration
My domain is: video.eirtrack.ie
I ran this command: n/a
It produced this output: n/a
My web server is (include version): NGINX, don't know version
The operating system my web server runs on is (include version): Windows 11
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): not using Certbot
Cert bundle was supplied via third party as a text file. It's been working for most visitors but some browsers (just recently) are returning 'insecure' warnings. When I check using 'whynopadlock' or similar services, reports indicate problems with Chain certs: 'You have an invalid or missing intermediate (bundle) certificate. This may not break your padlock on all browsers, but will on others. Please contact your SSL Vendor for assistance with this error"
Supplier says cert is good so there must be a config problem, software vendor says config is good so there must be a cert problem. I don't usually have to deal with SSL at this level so I'm really struggling with this! I've tried changing the order of the CA certs but it's not making any difference.
I agree there is a problem with your cert or which cert file you have in your nginx config.
But, you'll have to talk with your cert provider to get best instructions. You are using a cert from DigiCert and this is a forum for certs from Let's Encrypt.
This is a handy tool to view your config
Ah - thank you for your reply! I'm obviously in over my head but I'll try to follow up on an equivalent DigiCert forum.
