mail.isylum.org
sudo certbot certonly -v --apache
Could not find ssl_module; not disabling session tickets.
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): mail.isylum.org
Requesting a certificate for mail.isylum.org
http-01 challenge for mail.isylum.org
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
My web server is (include version): Apache HTTP Server 2.4.37:
Version : 2.4.37
Release : 64.module+el8.10.0+90271+3bc76a16
Architecture: x86_64
Install Date: Thu 13 Jun 2024 12:05:30 PM EDT
Group : System Environment/Daemons
License : ASL 2.0
Signature : RSA/SHA256, Wed 10 Apr 2024 03:40:16 AM EDT, Key ID 82562ea9ad986da3
Source RPM : httpd-2.4.37-64.module+el8.10.0+90271+3bc76a16.src.rpm
Build Date : Wed 10 Apr 2024 03:37:40 AM EDT
Relocations : (not relocatable)
URL : https://httpd.apache.org/
Summary : Apache HTTP Server
Description :
The Apache HTTP Server is a powerful, efficient, and extensible
web server.
cat /etc/redhat-release ; uname -a
Red Hat Enterprise Linux release 8.10 (Ootpa)
Linux mail.isylum.org 5.15.0-206.153.7.1.el8uek.x86_64 #2 SMP Wed May 22 20:49:34 PDT 2024 x86_64 x86_64 x86_64 GNU/Linux
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
Debug log:
2024-06-13 17:24:19,707:INFO:certbot._internal.auth_handler:Performing the following challenges:
2024-06-13 17:24:19,708:INFO:certbot._internal.auth_handler:http-01 challenge for mail.isylum.org
2024-06-13 17:24:19,710:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/auth_handler.py", line 88, in handle_authorizations
resps = self.auth.perform(achalls)
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot_apache/_internal/configurator.py", line 2474, in perform
http_response = http_doer.perform()
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot_apache/_internal/http_01.py", line 66, in perform
self._mod_config()
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot_apache/_internal/http_01.py", line 102, in _mod_config
selected_vhosts += self._relevant_vhosts()
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot_apache/_internal/http_01.py", line 145, in _relevant_vhosts
raise errors.PluginError(
certbot.errors.PluginError: Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
2024-06-13 17:24:19,710:DEBUG:certbot._internal.error_handler:Calling registered functions
2024-06-13 17:24:19,710:INFO:certbot._internal.auth_handler:Cleaning up challenges
2024-06-13 17:24:19,911:DEBUG:certbot._internal.log:Exiting abnormally:
File "/snap/certbot/3834/bin/certbot", line 8, in <module>
sys.exit(main())
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/main.py", line 19, in main
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/main.py", line 1894, in main
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/main.py", line 1600, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/main.py", line 143, in _get_and_save_cert
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/client.py", line 517, in obtain_and_enroll_certificate
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/client.py", line 428, in obtain_certificate
File "/var/lib/snapd/snap/certbot/3834/lib/python3.8/site-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
self._mod_config()
2024-06-13 17:24:19,912:ERROR:certbot._internal.log:Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
