Okay, i'm try to debug wplesk first then uplesk.
[root@wplesk ~]# curl -4 http://ifconfig.co
103.123.16.178
there is no log information about in the error log or access log
http://uplesk.citrahost.com/.well-known/acme-challenge/letsdebug-test
so, what next should i do ? create file on which directory sir ?
MikeMcQ
October 22, 2022, 3:50am
22
OK. The DNS IP matches the public IP of that server.
There is no need to create any files. Just run a Let's Debug test for wplesk and then show us the most recent log entries. You should see at least one access log entry for the letsdebug-test file request. It is fine if it returns a 404.
You should also see up to 4 requests from the Let's Encrypt servers but we want to see how many and which ones get through.
If the uplesk logs don't show any then some system in front of your server is intercepting these requests. Could you have a pfSense firewall active?
here is the access.log
172.104.24.29 - - [22/Oct/2022:10:52:10 +0700] "GET /.well-known/acme-challenge/letsdebug-test HTTP/1.1" 404 196 "-" "Mozilla/5.0 (compatible; Let's Debug emulating Let's Encrypt validation server; +https://letsdebug.net)"
3.120.152.97 - - [22/Oct/2022:10:52:10 +0700] "GET /.well-known/acme-challenge/NtwDAWreCGN7SMJJ-OxHMRhF8FAcEbvfn61FJfD-S5U HTTP/1.1" 404 196 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
52.88.151.109 - - [22/Oct/2022:10:52:10 +0700] "GET /.well-known/acme-challenge/NtwDAWreCGN7SMJJ-OxHMRhF8FAcEbvfn61FJfD-S5U HTTP/1.1" 404 196 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
18.217.173.5 - - [22/Oct/2022:10:52:10 +0700] "GET /.well-known/acme-challenge/NtwDAWreCGN7SMJJ-OxHMRhF8FAcEbvfn61FJfD-S5U HTTP/1.1" 404 196 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
MikeMcQ
October 22, 2022, 3:54am
24
I see @rg305 is now active and I was just signing off for night anyway. He will take good care of you.
of course, thanks for your help
rg305
October 22, 2022, 3:57am
26
404 error means something is off with your certbot command OR with your web server configuration.
which should I check part of the web server configuration because all the default configurations are applied ?
rg305
October 22, 2022, 4:08am
28
I see you wrote that you have Apache and nginx.
Which one is expected on that system?
And what was the complete certbot command ran?
I use reverse proxy nginx-apache. For webserver of course nginx as main
rg305
October 22, 2022, 4:10am
30
Please clarify that.
Maybe you can draw me a picture - lol
rg305
October 22, 2022, 4:25am
32
But there is a proxy in front of that?
Or that is a proxy?
rg305
October 22, 2022, 5:02am
34
If the Internet comes in from the left side, then let's have a look at what the Apache system is doing with the HTTP requests.
system
Closed
November 21, 2022, 5:02am
35
