I followed the letsencrypt instructions exactly, but it didn't work, so I did a certbot delete once, but when I restarted Apache, I got the following error and it didn't work.
What is the best way to reconfigure it?
Apr 06 19:13:03 wordpress-3-vm apachectl[28038]: AH00526: Syntax error on line 34 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
Apr 06 19:13:03 wordpress-3-vm apachectl[28038]: SSLCertificateFile: file '/etc/letsencrypt/live/test.xxxxxxxxxxx.co.jp/fullchain.pem' does not exist or is empty
Apr 06 19:13:03 wordpress-3-vm apachectl[28038]: Action 'start' failed.
Apr 06 19:13:03 wordpress-3-vm apachectl[28038]: The Apache error log may have more information.
Apr 06 19:13:03 wordpress-3-vm systemd[1]: apache2.service: Control process exited, code=exited status=1
Apr 06 19:13:03 wordpress-3-vm systemd[1]: Failed to start The Apache HTTP Server.
Hi @nobu,
You should delete /etc/apache2/sites-enabled/000-default-le-ssl.conf
and then restart Apache.
Thank you very much.
I tried deleting /etc/apache2/sites-enabled/000-default-le-ssl.conf and running it.
It changed to the following error, does that mean there is some file missing?
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2021-04-06 20:13:53 UTC; 24s ago
Process: 28668 ExecStop=/usr/sbin/apachectl stop (code=exited, status=1/FAILURE)
Process: 28676 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
Main PID: 28511 (code=exited, status=0/SUCCESS)
Apr 06 20:13:53 wordpress-3-vm systemd[1]: Starting The Apache HTTP Server...
Apr 06 20:13:53 wordpress-3-vm apachectl[28676]: apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Could not open configuration file
Apr 06 20:13:53 wordpress-3-vm apachectl[28676]: Action 'start' failed.
Apr 06 20:13:53 wordpress-3-vm apachectl[28676]: The Apache error log may have more information.
Apr 06 20:13:53 wordpress-3-vm systemd[1]: apache2.service: Control process exited, code=exited status=1
Apr 06 20:13:53 wordpress-3-vm systemd[1]: Failed to start The Apache HTTP Server.
Apr 06 20:13:53 wordpress-3-vm systemd[1]: apache2.service: Unit entered failed state.
Apr 06 20:13:53 wordpress-3-vm systemd[1]: apache2.service: Failed with result 'exit-code'.
You're running the restart command as root, right?
What's on line 225 of /etc/apache2/apache2.conf
? What does the log in /var/log/apache2
say?
The error log will be as follows.
[Tue Apr 06 19:58:45.678903 2021] [mpm_prefork:notice] [pid 28511] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2u configured -- resuming normal operations
[Tue Apr 06 19:58:45.678987 2021] [core:notice] [pid 28511] AH00094: Command line: '/usr/sbin/apache2'
[Tue Apr 06 20:13:53.095701 2021] [mpm_prefork:notice] [pid 28511] AH00169: caught SIGTERM, shutting down
How about the contents of this configuration file?
Line 225, which is as follows.
Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
It is true that if I commented this line 225, Apache worked, but the wordpress service did not work.
Are there other files still present in /etc/apache2/sites-enabled
The file was still there.
After deleting the file, I checked the site and it worked fine.
Thank you very much for your help.
