Oh! I think that worked! (Mostly automatically.)
At the end of the output, it said:
Created an SSL vhost at /private/etc/apache2/httpd-le-ssl.conf
Cannot find an SSLCertificateFile directive in /files/private/etc/apache2/httpd-le-ssl.conf/IfModule/VirtualHost. VirtualHost was not modified
Unable to find an SSLCertificateFile directive
¹ (Note: Full output of the command is at the bottom of this post.)
Despite what it says, there is no file at /private/etc/apache2/httpd-le-ssl.conf
In fact, there’s no httpd-le-ssl.conf
anywhere, at least I could not find one.
However, I decided to search for the error message “Unable to find an SSLCertificateFile directive” in the docs, and found that https://certbot.eff.org/docs/install.html?highlight=sslcertificatefile said to make sure that this was enabled:
LoadModule ssl_module libexec/apache2/mod_ssl.so
That line was commented out in my /etc/apache2/httpd.conf file, so I enabled it, and restarted apache.
Then I knew that I needed to add the certificate to the Server.app in Mac OS X.
In order to even see the certificates in Finder, I needed to change permissions on two folders:
sudo chmod 755 /etc/letsencrypt/live/
sudo chmod 755 /private/etc/letsencrypt/archive/
(both had been chmod 700
before)
Then I added the privkey.pem
and fullchain.pem
to ‘Certificates’ in Server.app
I enabled the key and now I can connect to https://mini.luo.ma !
Sooo… I guess that until I need to renew my certificate, I’m all set?
Thanks to everyone for their help! I literally could not have done it without you.
¹ Here’s the full output of the command that I ran:
% sudo certbot -a webroot -w /Users/luomat/Sites/mini.luo.ma -d mini.luo.ma -i apache
Password:
Plugins selected: Authenticator webroot, Installer apache
http-01 challenge for mini.luo.ma
Using the webroot path /Users/luomat/Sites/mini.luo.ma for all unmatched domains.
- Unable to install the certificate
/etc/letsencrypt/live/mini.luo.ma/fullchain.pem
/etc/letsencrypt/live/mini.luo.ma/privkey.pem
Your cert will expire on 2019-01-24. To obtain a new or tweaked
with the "certonly" option. To non-interactively renew *all* of
