Here is cat /etc/apache2/httpd.conf:
# This is the main Apache HTTP server configuration file. It contains the
# configuration directives that give the server its instructions.
# See <URL:http://httpd.apache.org/docs/2.4/> for detailed information.
# In particular, see
# <URL:http://httpd.apache.org/docs/2.4/mod/directives.html>
# for a discussion of each configuration directive.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "logs/access_log"
# with ServerRoot set to "/usr/local/apache2" will be interpreted by the
# server as "/usr/local/apache2/logs/access_log", whereas "/logs/access_log"
# will be interpreted as '/logs/access_log'.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# Do not add a slash at the end of the directory path. If you point
# ServerRoot at a non-local disk, be sure to specify a local disk on the
# Mutex directive, if file-based mutexes are used. If you wish to share the
# same ServerRoot for multiple httpd daemons, you will need to change at
# least PidFile.
ServerRoot "/usr"
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:/private/var/run
# Listen: Allows you to bind Apache to specific IP addresses and/or
# ports, instead of the default. See also the <VirtualHost>
# directive.
# Change this to Listen on specific IP addresses as shown below to
# prevent Apache from glomming onto all bound IP addresses.
#Listen 12.34.56.78:80
<IfDefine SERVER_APP_HAS_DEFAULT_PORTS>
Listen 8080
</IfDefine>
#<IfDefine !SERVER_APP_HAS_DEFAULT_PORTS>
# Listen 80
#Listen 80
#<VirtualHost *:80>
# DocumentRoot "/Users/luomat/Sites/mini.luo.ma"
# ServerName mini.luo.ma
# Other directives here
#</VirtualHost>
#</IfDefine>
Listen 80
<VirtualHost *:80>
RewriteEngine on
RewriteRule ^/.well-known/acme-challenge/([A-Za-z0-9-_=]+)$ /var/lib/letsencrypt/http_challenges/$1 [END]
<Directory /var/lib/letsencrypt/http_challenges>
Require all granted
</Directory>
<Location /.well-known/acme-challenge>
Require all granted
</Location>
</VirtualHost>
</IfDefine>
# Dynamic Shared Object (DSO) Support
# To be able to use the functionality of a module which was built as a DSO you
# have to place corresponding `LoadModule' lines at this location so the
# directives contained in it are actually available _before_ they are used.
# Statically compiled modules (those listed by `httpd -l') do not need
# to be loaded here.
# Example:
# LoadModule foo_module modules/mod_foo.so
LoadModule authn_file_module libexec/apache2/mod_authn_file.so
#LoadModule authn_dbm_module libexec/apache2/mod_authn_dbm.so
#LoadModule authn_anon_module libexec/apache2/mod_authn_anon.so
#LoadModule authn_dbd_module libexec/apache2/mod_authn_dbd.so
#LoadModule authn_socache_module libexec/apache2/mod_authn_socache.so
LoadModule authn_core_module libexec/apache2/mod_authn_core.so
LoadModule authz_host_module libexec/apache2/mod_authz_host.so
LoadModule authz_groupfile_module libexec/apache2/mod_authz_groupfile.so
LoadModule authz_user_module libexec/apache2/mod_authz_user.so
#LoadModule authz_dbm_module libexec/apache2/mod_authz_dbm.so
#LoadModule authz_owner_module libexec/apache2/mod_authz_owner.so
#LoadModule authz_dbd_module libexec/apache2/mod_authz_dbd.so
LoadModule authz_core_module libexec/apache2/mod_authz_core.so
#LoadModule authnz_ldap_module libexec/apache2/mod_authnz_ldap.so
LoadModule access_compat_module libexec/apache2/mod_access_compat.so
LoadModule auth_basic_module libexec/apache2/mod_auth_basic.so
#LoadModule auth_form_module libexec/apache2/mod_auth_form.so
#LoadModule auth_digest_module libexec/apache2/mod_auth_digest.so
#LoadModule allowmethods_module libexec/apache2/mod_allowmethods.so
#LoadModule file_cache_module libexec/apache2/mod_file_cache.so
#LoadModule cache_module libexec/apache2/mod_cache.so
#LoadModule cache_disk_module libexec/apache2/mod_cache_disk.so
#LoadModule cache_socache_module libexec/apache2/mod_cache_socache.so
#LoadModule socache_shmcb_module libexec/apache2/mod_socache_shmcb.so
#LoadModule socache_dbm_module libexec/apache2/mod_socache_dbm.so
#LoadModule socache_memcache_module libexec/apache2/mod_socache_memcache.so
#LoadModule watchdog_module libexec/apache2/mod_watchdog.so
#LoadModule macro_module libexec/apache2/mod_macro.so
#LoadModule dbd_module libexec/apache2/mod_dbd.so
#LoadModule dumpio_module libexec/apache2/mod_dumpio.so
#LoadModule echo_module libexec/apache2/mod_echo.so
#LoadModule buffer_module libexec/apache2/mod_buffer.so
#LoadModule data_module libexec/apache2/mod_data.so
#LoadModule ratelimit_module libexec/apache2/mod_ratelimit.so
LoadModule reqtimeout_module libexec/apache2/mod_reqtimeout.so
#LoadModule ext_filter_module libexec/apache2/mod_ext_filter.so
#LoadModule request_module libexec/apache2/mod_request.so
#LoadModule include_module libexec/apache2/mod_include.so
LoadModule filter_module libexec/apache2/mod_filter.so
#LoadModule reflector_module libexec/apache2/mod_reflector.so
#LoadModule substitute_module libexec/apache2/mod_substitute.so
#LoadModule sed_module libexec/apache2/mod_sed.so
#LoadModule charset_lite_module libexec/apache2/mod_charset_lite.so
#LoadModule deflate_module libexec/apache2/mod_deflate.so
#LoadModule xml2enc_module libexec/apache2/mod_xml2enc.so
#LoadModule proxy_html_module libexec/apache2/mod_proxy_html.so
LoadModule mime_module libexec/apache2/mod_mime.so
#LoadModule ldap_module libexec/apache2/mod_ldap.so
LoadModule log_config_module libexec/apache2/mod_log_config.so
#LoadModule log_debug_module libexec/apache2/mod_log_debug.so
#LoadModule log_forensic_module libexec/apache2/mod_log_forensic.so
#LoadModule logio_module libexec/apache2/mod_logio.so
LoadModule env_module libexec/apache2/mod_env.so
#LoadModule mime_magic_module libexec/apache2/mod_mime_magic.so
#LoadModule expires_module libexec/apache2/mod_expires.so
LoadModule headers_module libexec/apache2/mod_headers.so
#LoadModule usertrack_module libexec/apache2/mod_usertrack.so
##LoadModule unique_id_module libexec/apache2/mod_unique_id.so
LoadModule setenvif_module libexec/apache2/mod_setenvif.so
LoadModule version_module libexec/apache2/mod_version.so
#LoadModule remoteip_module libexec/apache2/mod_remoteip.so
#LoadModule proxy_module libexec/apache2/mod_proxy.so
#LoadModule proxy_connect_module libexec/apache2/mod_proxy_connect.so
#LoadModule proxy_ftp_module libexec/apache2/mod_proxy_ftp.so
#LoadModule proxy_http_module libexec/apache2/mod_proxy_http.so
#LoadModule proxy_fcgi_module libexec/apache2/mod_proxy_fcgi.so
#LoadModule proxy_scgi_module libexec/apache2/mod_proxy_scgi.so
#LoadModule proxy_uwsgi_module libexec/apache2/mod_proxy_uwsgi.so
#LoadModule proxy_fdpass_module libexec/apache2/mod_proxy_fdpass.so
#LoadModule proxy_wstunnel_module libexec/apache2/mod_proxy_wstunnel.so
#LoadModule proxy_ajp_module libexec/apache2/mod_proxy_ajp.so
#LoadModule proxy_balancer_module libexec/apache2/mod_proxy_balancer.so
#LoadModule proxy_express_module libexec/apache2/mod_proxy_express.so
#LoadModule proxy_hcheck_module libexec/apache2/mod_proxy_hcheck.so
#LoadModule session_module libexec/apache2/mod_session.so
#LoadModule session_cookie_module libexec/apache2/mod_session_cookie.so
#LoadModule session_dbd_module libexec/apache2/mod_session_dbd.so
LoadModule slotmem_shm_module libexec/apache2/mod_slotmem_shm.so
#LoadModule slotmem_plain_module libexec/apache2/mod_slotmem_plain.so
#LoadModule ssl_module libexec/apache2/mod_ssl.so
#LoadModule dialup_module libexec/apache2/mod_dialup.so
#LoadModule http2_module libexec/apache2/mod_http2.so
#LoadModule lbmethod_byrequests_module libexec/apache2/mod_lbmethod_byrequests.so
#LoadModule lbmethod_bytraffic_module libexec/apache2/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_bybusyness_module libexec/apache2/mod_lbmethod_bybusyness.so
##LoadModule lbmethod_heartbeat_module libexec/apache2/mod_lbmethod_heartbeat.so
LoadModule unixd_module libexec/apache2/mod_unixd.so
#LoadModule heartbeat_module libexec/apache2/mod_heartbeat.so
#LoadModule heartmonitor_module libexec/apache2/mod_heartmonitor.so
#LoadModule dav_module libexec/apache2/mod_dav.so
LoadModule status_module libexec/apache2/mod_status.so
LoadModule autoindex_module libexec/apache2/mod_autoindex.so
#LoadModule asis_module libexec/apache2/mod_asis.so
#LoadModule info_module libexec/apache2/mod_info.so
#LoadModule cgi_module libexec/apache2/mod_cgi.so
#LoadModule dav_fs_module libexec/apache2/mod_dav_fs.so
#LoadModule dav_lock_module libexec/apache2/mod_dav_lock.so
#LoadModule vhost_alias_module libexec/apache2/mod_vhost_alias.so
LoadModule negotiation_module libexec/apache2/mod_negotiation.so
LoadModule dir_module libexec/apache2/mod_dir.so
#LoadModule imagemap_module libexec/apache2/mod_imagemap.so
#LoadModule actions_module libexec/apache2/mod_actions.so
#LoadModule speling_module libexec/apache2/mod_speling.so
#LoadModule userdir_module libexec/apache2/mod_userdir.so
LoadModule alias_module libexec/apache2/mod_alias.so
LoadModule rewrite_module libexec/apache2/mod_rewrite.so
#LoadModule php7_module libexec/apache2/libphp7.so
#LoadModule perl_module libexec/apache2/mod_perl.so
LoadModule hfs_apple_module libexec/apache2/mod_hfs_apple.so
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User _www
Group _www
</IfModule>
# 'Main' server configuration
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition. These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
# ServerAdmin: Your address, where problems with the server should be
# e-mailed. This address appears on some server-generated pages, such
# as error documents. e.g. admin@your-domain.com
ServerAdmin you@example.com
# ServerName gives the name and port that the server uses to identify itself.
# This can often be determined automatically, but we recommend you specify
# it explicitly to prevent problems during startup.
# If your host doesn't have a registered DNS name, enter its IP address here.
#ServerName www.example.com:80
# Deny access to the entirety of your server's filesystem. You must
# explicitly permit access to web content directories in other
# <Directory> blocks below.
<Directory />
AllowOverride none
Require all denied
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# DocumentRoot: The directory out of which you will serve your
# documents. By default, all requests are taken from this directory, but
# symbolic links and aliases may be used to point to other locations.
DocumentRoot "/Library/WebServer/Documents"
<Directory "/Library/WebServer/Documents">
# Possible values for the Options directive are "None", "All",
# or any combination of:
# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
# The Options directive is both complicated and important. Please see
# http://httpd.apache.org/docs/2.4/mod/core.html#options
# for more information.
Options FollowSymLinks Multiviews
MultiviewsMatch Any
# AllowOverride controls what directives may be placed in .htaccess files.
# It can be "All", "None", or any combination of the keywords:
# AllowOverride FileInfo AuthConfig Limit
AllowOverride None
# Controls who can get stuff from this server.
Require all granted
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
DirectoryIndex index.html
</IfModule>
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.([Hh][Tt]|[Dd][Ss]_[Ss])">
Require all denied
</FilesMatch>
# Apple specific filesystem protection.
<Files "rsrc">
Require all denied
</Files>
<DirectoryMatch ".*\.\.namedfork">
Require all denied
</DirectoryMatch>
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog "/private/var/log/apache2/error_log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
<IfModule log_config_module>
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
<IfModule logio_module>
# You need to enable mod_logio.c to use %I and %O
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
</IfModule>
# The location and format of the access logfile (Common Logfile Format).
# If you do not define any access logfiles within a <VirtualHost>
# container, they will be logged here. Contrariwise, if you *do*
# define per-<VirtualHost> access logfiles, transactions will be
# logged therein and *not* in this file.
CustomLog "/private/var/log/apache2/access_log" common
# If you prefer a logfile with access, agent, and referer information
# (Combined Logfile Format) you can use the following directive.
#CustomLog "/private/var/log/apache2/access_log" combined
</IfModule>
<IfModule alias_module>
# Redirect: Allows you to tell clients about documents that used to
# exist in your server's namespace, but do not anymore. The client
# will make a new request for the document at its new location.
# Example:
# Redirect permanent /foo http://www.example.com/bar
# Alias: Maps web paths into filesystem paths and is used to
# access content that does not live under the DocumentRoot.
# Example:
# Alias /webpath /full/filesystem/path
# If you include a trailing / on /webpath then the server will
# require it to be present in the URL. You will also likely
# need to provide a <Directory> section to allow access to
# the filesystem path.
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the target directory are treated as applications and
# run by the server when requested rather than as documents sent to the
# client. The same rules about trailing "/" apply to ScriptAlias
# directives as to Alias.
ScriptAliasMatch ^/cgi-bin/((?!(?i:webobjects)).*$) "/Library/WebServer/CGI-Executables/$1"
</IfModule>
<IfModule cgid_module>
# ScriptSock: On threaded servers, designate the path to the UNIX
# socket used to communicate with the CGI daemon of mod_cgid.
#Scriptsock cgisock
</IfModule>
# "/Library/WebServer/CGI-Executables" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/Library/WebServer/CGI-Executables">
AllowOverride None
Options None
Require all granted
</Directory>
<IfModule headers_module>
# Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
# backend servers which have lingering "httpoxy" defects.
# 'Proxy' request header is undefined by the IETF, not listed by IANA
RequestHeader unset Proxy early
</IfModule>
<IfModule mime_module>
# TypesConfig points to the file containing the list of mappings from
# filename extension to MIME-type.
TypesConfig /private/etc/apache2/mime.types
# AddType allows you to add to or override the MIME configuration
# file specified in TypesConfig for specific file types.
#AddType application/x-gzip .tgz
# AddEncoding allows you to have certain browsers uncompress
# information on the fly. Note: Not all browsers support this.
#AddEncoding x-compress .Z
#AddEncoding x-gzip .gz .tgz
# If the AddEncoding directives above are commented-out, then you
# probably should define those extensions to indicate media types:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
# AddHandler allows you to map certain file extensions to "handlers":
# actions unrelated to filetype. These can be either built into the server
# or added with the Action directive (see below)
# To use CGI scripts outside of ScriptAliased directories:
# (You will also need to add "ExecCGI" to the "Options" directive.)
#AddHandler cgi-script .cgi
# For type maps (negotiated resources):
#AddHandler type-map var
# Filters allow you to process content before it is sent to the client.
# To parse .shtml files for server-side includes (SSI):
# (You will also need to add "Includes" to the "Options" directive.)
#AddType text/html .shtml
#AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type. The MIMEMagicFile
# directive tells the module where the hint definitions are located.
#MIMEMagicFile /private/etc/apache2/magic
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files. This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile on
TraceEnable off
# Supplemental configuration
# The configuration files in the /private/etc/apache2/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
Include /private/etc/apache2/extra/httpd-mpm.conf
# Multi-language error messages
#Include /private/etc/apache2/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
Include /private/etc/apache2/extra/httpd-autoindex.conf
# Language settings
#Include /private/etc/apache2/extra/httpd-languages.conf
# User home directories
#Include /private/etc/apache2/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include /private/etc/apache2/extra/httpd-info.conf
# Virtual hosts
#Include /private/etc/apache2/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include /private/etc/apache2/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include /private/etc/apache2/extra/httpd-dav.conf
# Various default settings
#Include /private/etc/apache2/extra/httpd-default.conf
# Configure mod_proxy_html to understand HTML4/XHTML1
<IfModule proxy_html_module>
Include /private/etc/apache2/extra/proxy-html.conf
</IfModule>
# Secure (SSL/TLS) connections
#Include /private/etc/apache2/extra/httpd-ssl.conf
# Note: The following must must be present to support
# starting without SSL on platforms with no /dev/random equivalent
# but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup builtin
SSLRandomSeed connect builtin
</IfModule>
Include /private/etc/apache2/other/*.conf
