My domain is: rpremo.io
PfSense Netgate SG-2100 running ...
21.05.1-RELEASE (arm64)
built on Wed Aug 04 09:50:08 EDT 2021
FreeBSD 12.2-STABLE
Apache running on RPI 4b but the certificate is offloaded to firewall. When I check the certificate at https://m.rpremo.io:8448 using godaddy ssl checker or any other checker its says the chain is incomplete (intermediary chain). I have installed the cross linked chain for both certificates in the PfSense Cerftificate manager and using HAProxy to tie to the certificates using the R3.
My hosting provider, if applicable, is: Self hosted at home on RPI4b
Yes
Installing certs local with key and point matrix config to the cert.
