Peer’s Certificate issuer is not recognized
The way I used to install a cert for apache webserver in the past is no longer working.
# SSL INSTALL SNAPD
sudo dnf -y install snapd
sudo systemctl start snapd
sudo systemctl enable snapd
sudo init 6
sudo snap install core; sudo snap refresh core
sudo ln -s /var/lib/snapd/snap /snap
sudo snap install --classic certbot
sudo ln -s /snap/bin/certbot /usr/bin/certbot
sudo dnf -y install certbot python3-certbot-apache mod_ssl
sudo nft -a list ruleset
sudo nft insert rule inet filter INPUT position 11 tcp dport {80, 443} accept
sudo systemctl restart httpd
sudo certbot --apache
Although I get "Successfully received certificate." I end up with an warning in Firefox after saying
Peer’s Certificate issuer is not recognized.
HTTP Strict Transport Security: false
HTTP Public Key Pinning: false
Certificate chain
Server version: Apache/2.4.37 (rocky)
Server built: Mar 24 2022 17:33:25
RockyLinux 4.18.0-348.20.1.el8_5.x86_64
certbot 1.22.0
Your client might not have the latest root cert store.
Is that really necessary?
Not when snap is being used. It might even pull in the non-snap-version of Certbot as a dependency, resulting in two different installations of Certbot.
Please share the hostname of the afflicted site.
@Osiris
no.longer.tld
Your site does not appear to be sending the Let's Encrypt certificate. Did Certbot output an installation error by any chance?
Could you please share the Apache configuration files?
This is kinda weird? Wouldn't it make more sense to put this configuration file in /sites-enabled/ to load it? Usually, Certbot handles all the stuff with this file, so maybe Certbot did it like that, but I find it kinda weird..
Not really anything strange with your configuration.. What's the output of apachectl -S ?
This one is probably the issue. Usually it's a good idea to have ssl.conf set some defaults, but it also has the same virtualhost as the ~le-ssl.conf file. You should put a different hostname in the ServerName directive of ssl.conf (e.g. example.com or something, as long as it isn't a real website), so Apache will use the ~le-ssl.conf file for your site instead of ssl.conf.
@Osiris
The ssl.conf has already set an example.com ServerName. It's commented out with # at the beginning.
#ServerName www.example.com:443
Should I set the real hostname in the httpd.conf AND in the honig.conf ?
I don't know about httpd.conf, but you should NOT use the real hostname in ssl.conf, that's what I was trying to tell you. You should use the ServerName what's now commented out.
So just uncomment the fake example.com in ssl.conf ?
Just to be clear, there is no real hostname in the ssl.conf
/etc/httpd/conf.d/ssl.conf
Or do you mean the
/etc/httpd/sites-available/honig-le-ssl.conf
I did that, removed the # in /etc/httpd/conf.d/ssl.conf to use the www.example.com (not sure why though), restarted httpd but still the same issue.
Also make sure that any other ServerName directives in ssl.conf are commented out.
After that, please show the output of apachectl -S again.
@Osiris
which ssl.conf are you talkin' about? Because the ServerName was commented out and never used or set to the real name.?!
Please uncomment the example.com ServerName directive, reload Apache and check again.
@Osiris
That's it! You solved it! :slight_smile:
Thanks for your patience. Never had to enable a fake ServerName in ssl.conf before. Will take notes for the future.
Thanks again, all the best. take care :slight_smile:
@rg305
not sure if "python3-certbot-apache" is necessary. Will try next time without it.
That's because without a ServerName it'll inherit the hostname from somewhere else, in this case the actual hostname of your site. Which was double with the configuration in the ~le-ssl.conf file. But because ssl.conf was loaded earlier, it probably took precedence somehow, overruling the virtualhost in the ~le-ssl.conf file.
