2022-08-10 14:24:09,505:DEBUG:certbot._internal.display.obj:Notifying user:
2022-08-10 14:24:09,506:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:24:09,508:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:24:09,510:DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:24:09,512:DEBUG:certbot._internal.log:Exiting abnormally:
File "./certbot", line 8, in <module>
sys.exit(main())
File "/opt/certbot/lib/python3.7/site-packages/certbot/main.py", line 19, in main
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/main.py", line 1744, in main
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/main.py", line 1630, in renew
renewal.handle_renewal_request(config)
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/renewal.py", line 511, in handle_renewal_request
f"{len(renew_failures)} renew failure(s), {len(parse_failures)} parse failure(s)")
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
2022-08-10 14:24:09,517:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:24:36,148:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:36,194:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:36,225:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:24:36,227:DEBUG:certbot._internal.main:Location of certbot entry point: ./certbot
2022-08-10 14:24:36,227:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:24:36,230:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:24:36,358:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:24:36,362:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:24:36,372:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:24:36,572:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:36,616:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:36,704:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x75329450> and installer <certbot._internal.cli.cli_utils._Default object at 0x75329450>
2022-08-10 14:24:36,706:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:24:36,707:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:24:36,708:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:24:36,709:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:24:36,710:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:24:36,925:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:36,968:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:37,110:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:24:37,143:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:24:37,193:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:24:37,194:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:24:37,196:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:24:37,197:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:24:37,198:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:24:37,199:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:24:37,203:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:24:37,214:DEBUG:certbot._internal.renewal:Traceback was:
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/renewal.py", line 481, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/main.py", line 1239, in renew_cert
installer, auth = plug_sel.choose_configurator_plugins(config, plugins, "certonly")
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/plugins/selection.py", line 224, in choose_configurator_plugins
diagnose_configurator_problem("authenticator", req_auth, plugins)
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/plugins/selection.py", line 328, in diagnose_configurator_problem
raise errors.PluginSelectionError(msg)
certbot.errors.PluginSelectionError: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:24:37,216:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:24:37,217:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:24:37,219:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:24:37,220:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:24:37,222:DEBUG:certbot._internal.log:Exiting abnormally:
File "./certbot", line 10, in <module>
sys.exit(main())
File "/usr/local/lib/python3.7/dist-packages/certbot/main.py", line 15, in main
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/main.py", line 1435, in main
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/main.py", line 1328, in renew
File "/usr/local/lib/python3.7/dist-packages/certbot/_internal/renewal.py", line 507, in handle_renewal_request
len(renew_failures), len(parse_failures)))
2022-08-10 14:24:37,226:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:24:54,542:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:54,587:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:24:54,618:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:24:54,621:DEBUG:certbot._internal.main:Location of certbot entry point: ./certbot
2022-08-10 14:24:54,621:DEBUG:certbot._internal.main:Arguments: []
2022-08-10 14:24:54,623:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:24:54,748:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:24:54,752:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:24:54,759:DEBUG:certbot._internal.main:Expected interfaces: None
2022-08-10 14:24:54,772:DEBUG:certbot._internal.main:Filtered plugins: PluginsRegistry(PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:24:54,776:DEBUG:certbot.display.util:Notifying user: * standalone
Description: Spin up a temporary webserver
Entry point: standalone = certbot._internal.plugins.standalone:Authenticator
* webroot
Description: Place files in webroot directory
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
2022-08-10 14:29:37,171:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:29:37,218:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:29:37,249:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:29:37,252:DEBUG:certbot._internal.main:Location of certbot entry point: ./certbot
2022-08-10 14:29:37,252:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:29:37,254:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:29:37,385:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:29:37,389:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:29:37,399:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:29:37,600:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:29:37,643:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:29:37,732:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x752e0250> and installer <certbot._internal.cli.cli_utils._Default object at 0x752e0250>
2022-08-10 14:29:37,734:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:29:37,735:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:29:37,736:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:29:37,737:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:29:37,738:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:29:37,950:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:29:37,993:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:29:38,142:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:29:38,176:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:29:38,226:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:29:38,228:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:29:38,230:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:29:38,231:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:29:38,232:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:29:38,233:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:29:38,236:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:29:38,247:DEBUG:certbot._internal.renewal:Traceback was:
2022-08-10 14:29:38,249:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:29:38,250:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:29:38,252:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:29:38,253:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:29:38,255:DEBUG:certbot._internal.log:Exiting abnormally:
sys.exit(main())
2022-08-10 14:29:38,260:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:29:58,415:DEBUG:certbot._internal.main:certbot version: 1.29.0
2022-08-10 14:29:58,419:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2022-08-10 14:29:58,420:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:29:58,422:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:29:58,555:DEBUG:certbot._internal.log:Root logging level set at 30
2022-08-10 14:29:58,570:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:29:58,898:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x753b7430> and installer <certbot._internal.cli.cli_utils._Default object at 0x753b7430>
2022-08-10 14:29:58,900:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:29:58,901:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 14:29:58,902:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:29:58,903:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 14:29:58,904:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:29:59,213:DEBUG:urllib3.connectionpool:Starting new HTTP connection (1): r3.o.lencr.org:80
2022-08-10 14:29:59,297:DEBUG:urllib3.connectionpool:http://r3.o.lencr.org:80 "POST / HTTP/1.1" 200 503
2022-08-10 14:29:59,309:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:29:59,350:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:29:59,401:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:29:59,402:INFO:certbot._internal.renewal:Certificate is due for renewal, auto-renewing...
2022-08-10 14:29:59,404:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:29:59,405:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:29:59,406:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:29:59,420:DEBUG:certbot._internal.renewal:Traceback was:
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/renewal.py", line 484, in handle_renewal_request
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/main.py", line 1538, in renew_cert
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/plugins/selection.py", line 257, in choose_configurator_plugins
File "/opt/certbot/lib/python3.7/site-packages/certbot/_internal/plugins/selection.py", line 377, in diagnose_configurator_problem
2022-08-10 14:29:59,422:DEBUG:certbot._internal.display.obj:Notifying user:
2022-08-10 14:29:59,425:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:29:59,428:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:29:59,431:DEBUG:certbot._internal.display.obj:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:29:59,434:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/bin/certbot", line 8, in <module>
sys.exit(main())
2022-08-10 14:29:59,438:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:30:48,293:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:30:48,338:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:30:48,368:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:30:48,371:DEBUG:certbot._internal.main:Location of certbot entry point: /home/pi/.local/bin/certbot
2022-08-10 14:30:48,371:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:30:48,374:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:30:48,502:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:30:48,506:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:30:48,515:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:30:48,713:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:30:48,756:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:30:48,842:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x7524b8b0> and installer <certbot._internal.cli.cli_utils._Default object at 0x7524b8b0>
2022-08-10 14:30:48,844:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:30:48,845:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 14:30:48,846:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:30:48,846:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 14:30:48,847:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:30:49,055:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:30:49,099:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:30:49,249:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:30:49,283:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:30:49,332:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:30:49,333:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:30:49,335:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:30:49,336:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:30:49,337:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:30:49,338:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:30:49,342:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:30:49,353:DEBUG:certbot._internal.renewal:Traceback was:
2022-08-10 14:30:49,354:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:30:49,355:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:30:49,357:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:30:49,358:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:30:49,360:DEBUG:certbot._internal.log:Exiting abnormally:
File "/home/pi/.local/bin/certbot", line 10, in <module>
sys.exit(main())
2022-08-10 14:30:49,365:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:33:31,020:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:31,067:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:31,099:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:33:31,101:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2022-08-10 14:33:31,101:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:33:31,103:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:33:31,230:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:33:31,234:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:33:31,245:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:33:31,451:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:31,494:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:31,579:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x7526cff0> and installer <certbot._internal.cli.cli_utils._Default object at 0x7526cff0>
2022-08-10 14:33:31,581:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:33:31,582:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 14:33:31,583:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:33:31,584:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 14:33:31,585:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:33:31,791:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:31,841:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:31,989:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:33:32,023:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:33:32,075:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:33:32,076:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:33:32,078:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:33:32,079:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:33:32,080:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:33:32,081:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:33:32,085:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:33:32,096:DEBUG:certbot._internal.renewal:Traceback was:
2022-08-10 14:33:32,098:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:33:32,100:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:33:32,102:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:33:32,104:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:33:32,110:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/bin/certbot", line 10, in <module>
sys.exit(main())
2022-08-10 14:33:32,120:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:33:43,614:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:43,659:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:43,689:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:33:43,691:DEBUG:certbot._internal.main:Location of certbot entry point: ./certbot
2022-08-10 14:33:43,692:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:33:43,694:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:33:43,820:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:33:43,823:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:33:43,833:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:33:44,030:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:44,073:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:44,159:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x7529c650> and installer <certbot._internal.cli.cli_utils._Default object at 0x7529c650>
2022-08-10 14:33:44,161:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:33:44,162:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:33:44,163:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:33:44,164:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:33:44,165:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:33:44,371:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:44,413:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:33:44,531:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:33:44,564:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:33:44,612:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:33:44,614:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:33:44,615:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:33:44,617:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:33:44,618:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:33:44,619:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:33:44,622:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:33:44,633:DEBUG:certbot._internal.renewal:Traceback was:
2022-08-10 14:33:44,635:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:33:44,636:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:33:44,637:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:33:44,639:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:33:44,640:DEBUG:certbot._internal.log:Exiting abnormally:
sys.exit(main())
2022-08-10 14:33:44,645:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:36:52,141:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:36:52,187:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:36:52,218:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:36:52,220:DEBUG:certbot._internal.main:Location of certbot entry point: ./certbot
2022-08-10 14:36:52,221:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 14:36:52,223:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:36:52,351:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:36:52,354:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:36:52,364:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:36:52,566:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:36:52,610:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:36:52,698:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x752a6690> and installer <certbot._internal.cli.cli_utils._Default object at 0x752a6690>
2022-08-10 14:36:52,699:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:36:52,700:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:36:52,701:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 14:36:52,702:DEBUG:certbot._internal.cli:Var server={'dry_run', 'staging'} (set by user).
2022-08-10 14:36:52,703:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 14:36:52,914:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:36:52,957:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:36:53,107:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:36:53,140:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:36:53,190:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:36:53,192:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:36:53,193:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:36:53,195:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:36:53,196:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:36:53,196:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:36:53,200:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:36:53,211:DEBUG:certbot._internal.renewal:Traceback was:
2022-08-10 14:36:53,213:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:36:53,214:ERROR:certbot._internal.renewal:All simulated renewals failed. The following certificates could not be renewed:
2022-08-10 14:36:53,216:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:36:53,217:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:36:53,219:DEBUG:certbot._internal.log:Exiting abnormally:
sys.exit(main())
2022-08-10 14:36:53,223:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 14:37:21,311:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:37:21,357:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:37:21,387:DEBUG:certbot._internal.main:certbot version: 1.15.0
2022-08-10 14:37:21,389:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2022-08-10 14:37:21,390:DEBUG:certbot._internal.main:Arguments: []
2022-08-10 14:37:21,392:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 14:37:21,515:DEBUG:certbot._internal.log:Root logging level set at 20
2022-08-10 14:37:21,519:INFO:certbot._internal.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-08-10 14:37:21,528:DEBUG:certbot.display.util:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 14:37:21,729:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:37:21,772:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:37:21,858:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x752a8390> and installer <certbot._internal.cli.cli_utils._Default object at 0x752a8390>
2022-08-10 14:37:22,068:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:37:22,111:WARNING:certbot._internal.plugins.disco:PluginEntryPoint#certbot-dns-duckdns:dns-duckdns does not provide IPluginFactory, skipping
2022-08-10 14:37:22,255:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 14:37:22,288:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 14:37:22,338:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 14:37:22,339:INFO:certbot._internal.renewal:Cert is due for renewal, auto-renewing...
2022-08-10 14:37:22,341:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 14:37:22,342:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 14:37:22,343:DEBUG:certbot._internal.plugins.selection:Selected authenticator None and installer None
2022-08-10 14:37:22,344:INFO:certbot._internal.main:Could not choose appropriate plugin: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:37:22,348:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 14:37:22,358:DEBUG:certbot._internal.renewal:Traceback was:
2022-08-10 14:37:22,360:DEBUG:certbot.display.util:Notifying user:
2022-08-10 14:37:22,361:ERROR:certbot._internal.renewal:All renewals failed. The following certificates could not be renewed:
2022-08-10 14:37:22,363:ERROR:certbot._internal.renewal: /etc/letsencrypt/live/grembeirn.duckdns.org/fullchain.pem (failure)
2022-08-10 14:37:22,364:DEBUG:certbot.display.util:Notifying user: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
2022-08-10 14:37:22,366:DEBUG:certbot._internal.log:Exiting abnormally:
sys.exit(main())
2022-08-10 14:37:22,370:ERROR:certbot._internal.log:1 renew failure(s), 0 parse failure(s)
2022-08-10 16:33:58,381:DEBUG:certbot._internal.main:certbot version: 1.29.0
2022-08-10 16:33:58,386:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2022-08-10 16:33:58,386:DEBUG:certbot._internal.main:Arguments: ['--dry-run']
2022-08-10 16:33:58,388:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-08-10 16:33:58,523:DEBUG:certbot._internal.log:Root logging level set at 30
2022-08-10 16:33:58,537:DEBUG:certbot._internal.display.obj:Notifying user: Processing /etc/letsencrypt/renewal/grembeirn.duckdns.org.conf
2022-08-10 16:33:58,864:DEBUG:certbot._internal.plugins.selection:Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x754f59b0> and installer <certbot._internal.cli.cli_utils._Default object at 0x754f59b0>
2022-08-10 16:33:58,866:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 16:33:58,867:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 16:33:58,868:DEBUG:certbot._internal.cli:Var dry_run=True (set by user).
2022-08-10 16:33:58,869:DEBUG:certbot._internal.cli:Var server={'staging', 'dry_run'} (set by user).
2022-08-10 16:33:58,870:DEBUG:certbot._internal.cli:Var account={'server'} (set by user).
2022-08-10 16:33:59,180:DEBUG:urllib3.connectionpool:Starting new HTTP connection (1): r3.o.lencr.org:80
2022-08-10 16:33:59,261:DEBUG:urllib3.connectionpool:http://r3.o.lencr.org:80 "POST / HTTP/1.1" 200 503
2022-08-10 16:33:59,273:DEBUG:certbot.ocsp:OCSP response for certificate /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is signed by the certificate's issuer.
2022-08-10 16:33:59,314:DEBUG:certbot.ocsp:OCSP certificate status for /etc/letsencrypt/archive/grembeirn.duckdns.org/cert7.pem is: OCSPCertStatus.GOOD
2022-08-10 16:33:59,365:DEBUG:certbot._internal.storage:Should renew, less than 30 days before certificate expiry 2022-08-26 21:21:08 UTC.
2022-08-10 16:33:59,366:INFO:certbot._internal.renewal:Certificate is due for renewal, auto-renewing...
2022-08-10 16:33:59,368:DEBUG:certbot._internal.plugins.selection:Requested authenticator dns-duckdns and installer None
2022-08-10 16:33:59,369:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2022-08-10 16:33:59,370:ERROR:certbot._internal.renewal:Failed to renew certificate grembeirn.duckdns.org with error: The requested dns-duckdns plugin does not appear to be installed
2022-08-10 16:33:59,382:DEBUG:certbot._internal.renewal:Traceback was:
